You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Its all in fun.. Just go's to show you the drive line losses in a Super Duty truck. Not really a fair comparo as the F350 is a 4x4 Crew Cab and the F150 is a 2wd short bed. Its been fun to compare the two motors so far. Transmissions are very very similar in function both being select a shift.
So the 5.0 makes more power and torque than the 6.2 at any similar rpm...Why aren't they putting the 5.0 in the superduty?
Do you really think that former V10 buyers would accept a 5.0 as a replacement? I don't think most would be happy about that. I believe the 6.2 makes a bit more power in the same chassis though. There is way less drive train loss in a F150 than a Super Duty. 5.0 Ecoboost in a F550? Sure sign me up!
Wellllll. I WAS going to buy a tuner from ya Mike but I'm not so sure I like you anymore I could have done without seeing that. I pondered forever about going to a Superduty because 2/3rd of the time I DON'T need one. And now that they upped the tow rating to 11,300 # or something like that, I would have been just fine with the new F-150 6 foot bed and 5L. Oh well, my Superduty will look WAAAY cooler on 35's then any dumb old stupid pidily 1/2 ton. That's my story and I'm sti sti stickin to it.
__________________
White tri-coat metallic 2011 F-250Lariat CC 4x4 Off-Road, 6.2L, 4.30 gears, SB, 275-70-18 Michelin LTX AT2
HAULIN A#% AND SUCKING GAS
Actually, the 5.0 is rated to tow about 2-3K pounds less than that. Only the Ecoboost and 6.2 are rated for 11,300#.
LOL.. I still think you made the right choice in the Superduty. Now you just need more power to turn those 35's..
Heres a little towing report on the 5.0 i posted over in the f150 section yesterday.
Ok spent the last 2 days working on the factory tow/haul mode strategies with trailer in tow running our 87 perf-tow calibration. Background on trailer is it’s a max 7000 lb. capacity trailer and with the dyno gear in it, it is approx 4000 lbs. The crappy part about the trailer is it’s a brick moving through the air. Also our truck has 3.55 gear set.
Factory tow/haul strategies in a nut shell i think are weak. 6th gear is useless under 60 mph towing even this trailer. Coasting or slowing down the downshifts do not come on soon enough to keep the rpms up in torque range and when back in throttle multiple down shifts occur. Gears 2nd, 3rd and 4th are the gears the truck likes to run at under 60 mph towing this trailer but its in 6th gear at 50 mph lugging engine. Once rpm builds to 3000 plus the truck pulls like a champ but factory strategies keep rpms low.
For you guys going to tow a travel trailer camper or trailers over 5000 lbs the factory strategies will hunt all over the place in tow/haul mode. This is the same thing we have seen with the 6.2L SD tow/haul mode. Lugging the engine and not knowing what gear to stay in is terrible. (my opinion) And after about 150 miles and multiple changes the tow/haul mode works like what I feel it should keeps the engine RPMs elevated to take advantage of the torque band in this 5.0 less downshifting and taking advantage of gears 2nd, 3rd and 4th more. And by the way in our testing we avg. 10.4 mpg pulling this trailer at speeds to 65 mph and in stop and go traffic.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
