Oil in Air Charge Cooler? Is that ok? - Ford Truck Enthusiasts Forums
Old 01-15-2011, 02:19 PM
wstone wstone is offline
wstone is starting off with a positive reputation.
I noticed when I pulled off the air charge cooler hose to install my new Gillette Diesel fuel pressure spring that there was oil in the air charge cooler. Is that ok? or is it something I should be worried about. As a side note, I recently installed an Amsoil bypass engine oil filter.
<img src="http://img25.imageshack.us/img25/7135/img0438hx.jpg" alt="Image Hosted by ImageShack.us"/><br/>By <a target="_new" href="http://profile.imageshack.us/user/live2snowboard">live2snowboard</a> at 2011-01-15
Old 01-15-2011, 02:21 PM
gearloose1 gearloose1 is offline
gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.
A little bit of oil is normal from the Crankcase Ventilation system.
But if you find large amounts of oil.. not normal.
Old 01-15-2011, 02:35 PM
bismic's Avatar
bismic bismic is online now
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
The gillette spring will put your fuel pressure over the recommended max value of 75 psig. It could cause injector o-rings to leak. The upgraded factory fuel pressure regulator spring is what you need.
Old 01-15-2011, 02:48 PM
a711112a a711112a is offline
a711112a is starting off with a positive reputation.
wstone, What is the hose that is coming off your oil filter lid for?
Old 01-15-2011, 02:49 PM
69cj's Avatar
69cj 69cj is online now
69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future
I would assume oil press.
Old 01-15-2011, 02:56 PM
amdriven2liv's Avatar
amdriven2liv amdriven2liv is offline
I'm hitting easy street
amdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputation
That's his oil bypass filter hose.
Old 01-15-2011, 02:58 PM
davidkstyler's Avatar
davidkstyler davidkstyler is offline
davidkstyler has a good reputation on FTE.davidkstyler has a good reputation on FTE.
Quote:
Looks like a by-pass filter that drains into the oil filler
Old 01-15-2011, 03:00 PM
by pass filter. why? what is the benefit?
Old 01-15-2011, 03:03 PM
69cj's Avatar
Didn't notice the filter out in the north forty. My boo-boo.
Old 01-15-2011, 03:08 PM
He has another thread with a different pic. Shows how they both fit in there.
Old 01-15-2011, 10:30 PM
Quote:
Dang, I should have checked here before I got the spring. Any idea what the upgraded factory spring runs? And a part number if you have it?
Thanks
Old 01-15-2011, 10:52 PM
bismic's Avatar
Regulator kit part # 3C3Z-9T517-AG. I think you can get it for around $50.
I tried the Gillete spring and my fuel pressure went to 100 psig. I got it out of there immediately. Lots of similar stories.
Old 01-15-2011, 11:00 PM
hubler13f's Avatar
hubler13f hubler13f is offline
hubler13f has a good reputation on FTE.hubler13f has a good reputation on FTE.
I've also got the GDS spring and have been running it for about 2 years now, no problems with the injectors yet. But Bismic is right that it will jump the fuel pressure up there above the recomended pressure.
Oil in IC system is normal due to the CCV as stated above.
Old 01-16-2011, 07:40 PM
bismic's Avatar
Quote:
Good to know - thanks
7.5L Ford 460 Oil Cooler Heat Exchanger Failure F350JOHN Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 240 08-30-2016 02:04 PM
1979 F250 Rust Woes rlacan71 1973 - 1979 F-100 & Larger F-Series Trucks 13 08-19-2015 03:07 PM
Hutch's 1991 F250 build thread Hutch17 1987 - 1996 F150 & Larger F-Series Trucks 175 11-07-2013 09:25 AM
Amsoil Bypass and Coolant Filter both fit under the hood. wstone 6.0L Power Stroke Diesel 31 07-09-2011 05:27 PM
Just some new Additions to the Truck. TheBigBee 1999 to 2016 Super Duty 30 02-08-2010 10:09 PM
Tags
350, 60, 60l, air, charge, cooler, diesel, f250, f350, filter, ford, hose, hoses, oil, powerstroke
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
