Rear Hatch Broken Lock Fix - Pics Inside - Page 3 - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
  #31
Old 07-28-2014, 05:47 PM
EXv10 EXv10 is offline
EXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputation
Quote:
Originally Posted by NikiLynn View Post
Ok. Well, I had a brain fart and realize that I don't NEED the key cylinder in working order for the door to lock as long as the actuator is in working order, which it is. I already ordered the key cylinder, so it will be a project for...someday. Thanks for letting me 'talk it out' to myself on the forum.
But how are you going to get in there when the actuator goes?
  #32
Old 07-28-2014, 06:37 PM
mecdac's Avatar
mecdac mecdac is online now
If it flies, it dies
mecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputation
Talking
Quote:
Originally Posted by EXv10 View Post
Maybe not, did you see my write-up on that? It might be in the folder.
Soak it in one one those "super" penetrating oils overnight and use a little pick to scrape the rust etc, it should free up...........mine did, see my thread on it (should be in the tech folder).
Yep it's in my thread.
Look at me now!
  #33
Old 07-28-2014, 07:10 PM
Medac; is that your Christmas costume, or did you just borrow it?
  #34
Old 07-28-2014, 07:25 PM
NikiLynn NikiLynn is offline
NikiLynn is starting off with a positive reputation.
Valid point, I hadn't considered that. I ordered the door cylinder, so we'll get to that project sooner than later, I suppose. Just glad the door actually locks now. Anyone chance out the cylinder back there before? It can be as easy as slipping off the metal wire clip, and then replacing, right? Didn't want to tinker with it too much until I got the part in.
  #35
Old 07-28-2014, 07:31 PM
  #36
Old 07-28-2014, 07:35 PM
Valid point, I hadn't considered that. I ordered the door cylinder, so I'll get to that project sooner than later, I suppose. Just glad the door actually locks now. Anyone change out the cylinder back there before? It can't be as easy as slipping off the metal wire clip, and then replacing, right? Didn't want to tinker with it too much until I got the part in.
  #37
Old 07-28-2014, 08:28 PM
  #38
Old 08-08-2014, 12:52 PM
David - WI David - WI is offline
David - WI is gaining momentum as a positive member of FTE.
Hi,
I registered here just to say "thank you" because I've been able fix a couple of common Excursion problems (door ajar light, stuck hatch lock, ripped copper strip in the map lights, found keyless entry code) with help from you guys.
Anyway, I got the hatch lock out and spent an hour soaking and poking at it... and finally took it apart and found the brass tumblers or pins were trashed. I spent another hour and got all (6?) to move but they wouldn't "spring back" so now the lock stayed "unlocked" when you pulled the key out.
As a long shot I googled for an Excursion lock cylinder and found a guy on Ebay (wolfsecurityhardware) selling complete sets of ignition, door, and hatch locks with new keys OR the individual locks and for $9 extra he'll key them to match your key by sending him a hi-res photo of your key.
I have no affiliation with him and I just paid the extra $9 this morning so I don't have the lock yet... but for about $35 I wish I wouldn't have wasted hours trying to free up the old one.
I'm just posting because I'm sure there are other people who's locks are as corroded as mine who don't want extra keys just for the hatch.
David
  #39
Old 08-08-2014, 02:23 PM
Apocalypse's Avatar
Apocalypse Apocalypse is offline
Finally happy...
Apocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputation
That's not a bad deal really... I have a southern truck so no corrosion, but if I needed them all done that's a hell of a deal!
  #40
Old 08-11-2014, 12:04 PM
Worked out great, couldn't be happier. New lock, gasket, and a pair of non-PATS door keys that are keyed to match my door/ignition locks for $35.
I blasted the rust off the old "arm" and gave it a naval jelly soak and coat of aluminum paint... then popped it onto the new lock.
(Yikes... I didn't intend the photo to be so huge!)
  #41
Old 03-26-2016, 11:32 PM
mrc00l88 mrc00l88 is offline
mrc00l88 is starting off with a positive reputation.
How does the key lock work? Is the lock cylinder just connected to the rod with the 'clip'? I bought a new lock cylinder (I bought truck with the lock all corroded - so not sure if the lock worked before) but if I turn the key to lock or unlock it doesn't do anything just pushes the rod a bit in and out of its hole? I can't find any diagrams or anything online, any help would be appreciated.
Yet Another Highboy Build... Highboy74 1973 - 1979 F-100 & Larger F-Series Trucks 3 10-27-2012 12:40 AM
1974 Highboy Front Dana 60 swap Highboy74 1973 - 1979 F-100 & Larger F-Series Trucks 16 07-24-2012 10:53 PM
460 Flex plate question with pictures. Highboy74 1973 - 1979 F-100 & Larger F-Series Trucks 1 04-16-2012 10:04 PM
Need some help, like always. Pics ah1988 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 23 01-31-2012 04:44 PM
Pic of new wheels and tires... nomorecummins 6.4L Power Stroke Diesel 16 11-02-2010 10:15 AM
Tags
2001, actuator, door, excursion, explorer, fix, ford, hatch, hatchback, lock, panel, pic, rear, remove, repair
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
