Rear Hatch Broken Lock Fix - Pics Inside - Page 2 - Ford Truck Enthusiasts Forums
Old 06-28-2014, 04:14 PM
Bigpipes 35's Avatar
Bigpipes 35 Bigpipes 35 is offline
Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.
Was just reminded we are commenting on a 4 year old thread..
Thanks Mec..
Old 06-28-2014, 04:39 PM
mecdac's Avatar
mecdac mecdac is online now
If it flies, it dies
mecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputation
Wink
Quote:
Thanks Mec..
Oh, it's well done with parts **** and all.
The OP has not been logged on to the forum in almost three years.
Old 06-28-2014, 07:55 PM
sddesigns's Avatar
sddesigns sddesigns is offline
sddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputation
Thanks Mec..
Great to see it revived to help others out again!
Old 06-28-2014, 08:41 PM
EXv10 EXv10 is offline
EXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputation
Old threads aren't bad threads.
Old 06-29-2014, 01:29 AM
kevin.ford-trucks kevin.ford-trucks is offline
kevin.ford-trucks is starting off with a positive reputation.
Yeah, great post. I had gone through the procedure to fix the actuator motor and when I reassembled, it still would not drive the latch. I fiddled with the latch for 2 hours before giving up and searching. Bingo. This was spot on. This AM I ran PB blaster through it for an hour until finally it works smoothly. I have a couple miles of gravel road and the dust that gets stirred up wreaks havoc on parts like this. This post was a HUGE plus. I don't think I would have found the source of the issue, nor persevered long enough to get it resolved. Maybe the OP will stop by someday. I know I have gone years but always come back when the going gets tough.
Old 06-29-2014, 01:32 AM
My key lock still won't work however :-( it's just frozen.
Old 06-29-2014, 09:50 PM
Quote:
Maybe not, did you see my write-up on that? It might be in the folder.
Old 07-01-2014, 07:12 PM
stpete stpete is offline
stpete has a very good reputation on FTE.stpete has a very good reputation on FTE.stpete has a very good reputation on FTE.stpete has a very good reputation on FTE.
Thanks everyone. It's nice to know exactly what to expect. Makes a potentially frustrating job into a 10 minute quickie. Mine wasn't too dirty (unusual for this truck), so I just blasted it with some air and put a little light oil on it.
Old 07-01-2014, 08:47 PM
bbacon bbacon is offline
bbacon is starting off with a positive reputation.
Sweet How to
Thank you for the how to and pics. Need to do on my 2000. Have you had problems with the glass door being released slightly and the lights staying on? Mine has killed two batteries from this. It will come loose while driving when you park and run into store interior lights will still be on eventually battery kicks it.
Thanks again
Old 07-28-2014, 11:31 AM
NikiLynn NikiLynn is offline
NikiLynn is starting off with a positive reputation.
My back door lock wasn't working so I finally popped off the trim to take a look today. I noticed right away that the actual lock was pretty crusty looking. The little white plastic clip that, I suppose, holds the locking bar in place was very crusty. I barely touched it and it broke in half, causing the locking bar to fall off the lock Ok. Moved on to the actuator and now that the bar is free from the lock, it seems to be working fine. I took my truck key and placed it in the lock to see if it would move. It is still frozen in time. I'm assuming this is my problem and NOT the actuator.
So what now? Obviously, I'll lube the crud out of it to see if I can free it up, but do I need to replace the entire lock because of the little plastic guide thing? I've been all over Google and am finding a fix for the actuator, but not the actual lock.
Anyone deal with this before? Thanks!
Old 07-28-2014, 12:03 PM
Apocalypse's Avatar
Apocalypse Apocalypse is offline
Apocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputation
I think you're on the right track with lubing it. If possible remove it and let it soak in a small plastic tub (or platinum tub, I don't care) for a few days agitating it and working the lock whenever able. The other option is to just hose it down with silicone lube every day and work that thing like it owes you money. It'll eventually break free... or break.
Old 07-28-2014, 12:06 PM
Ok, little more research into this and I see now I have to replace the key lock cyclinder. Kind of sucks to have a different key for the back, but in all the years I've had this truck I've never used the key to open the back, just the remote. I'm finding the lock on ebay, but they're saying right or left. Anyone know which one the back liftgate would be? The actuator is drivers side, if I remember correctly, so is the lock the same as drivers too?
  #28
Old 07-28-2014, 12:12 PM
Soak it in one one those "super" penetrating oils overnight and use a little pick to scrape the rust etc, it should free up...........mine did, see my thread on it (should be in the tech folder).
  #29
Old 07-28-2014, 12:38 PM
I can't soak it, it's broke. Check out this:
See the red or blue plastic piece? That's what holds the bar, which connects to the actuator. Well my plastic piece is split in half. So I see no way around replacing the lock cylinder, I just don't know hot to go about doing it. Who's bright idea it was to make such an important piece plastic?
  #30
Old 07-28-2014, 01:13 PM
Ok. Well, I had a brain fart and realize that I don't NEED the key cylinder in working order for the door to lock as long as the actuator is in working order, which it is. I already ordered the key cylinder, so it will be a project for...someday. Thanks for letting me 'talk it out' to myself on the forum.
E Van Door Panel Removal JWA Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 7 02-21-2017 11:08 AM
Door Panel Removal JWA 1968-2013 Full Size Vans 21 05-20-2016 06:17 AM
Cluster Anatomy JWA 1968-2013 Full Size Vans 9 09-29-2015 08:53 AM
broken truck pics arkredneck 1994.5 - 1997 7.3L Power Stroke Diesel 5 10-11-2011 03:01 PM
new to the show ol' black 1987 - 1996 F150 & Larger F-Series Trucks 2 04-19-2011 03:53 AM
Tags
2001, actuator, door, excursion, explorer, fix, ford, hatch, hatchback, lock, panel, pic, rear, remove, repair
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
