MAP Sensor - Ford Truck Enthusiasts Forums
MAP Sensor
Old 12-03-2001, 11:03 AM
amsnss's Avatar
amsnss amsnss is offline
amsnss is starting off with a positive reputation.
MAP Sensor
Hey all,
Question: Are there any signs that a MAP sensor may be going out?
Old 12-03-2001, 10:39 PM
oldblue18's Avatar
oldblue18 oldblue18 is offline
oldblue18 is starting off with a positive reputation.
MAP Sensor
When the MAP sensor went out on my Bronco, it had a very eradic idle. It would stall out if I did not crank it up with my foot on the gas. It would stall at a trafic light if foot was not on gas revving it to about 1500rpm. The rpm's would jump 400-500 when driving 60 MPH. You'll definately noice if it's going out.... It was a cheap fix though, once we found out that it was the problem.
Jon
1989 F-150 XL- 4x4, 302, M50D
1995 Bronco Eddie Bauer- 351W, E40D
Old 12-04-2001, 09:31 AM
lanero lanero is offline
lanero is starting off with a positive reputation.
MAP Sensor
When the MAP sensor died in my truck, I noticed a decrease in gas milage. About a 25% decrease. I never recieved a check engine light, but when I pulled the codes, it threw out a code that the MAP was not responding.
Roger Lane
Old 12-04-2001, 10:22 AM
amsnss's Avatar
MAP Sensor
When running the KOEO test, It showed that there was a possible short in the map sensor. I did unplug the sensor and then start the truck, but it wouldn't even idle at all then. Plugged it back up and it ran, but after it got warm, it started the same old rough idling up and down at stop lights, stop signs and sometimes in park.
Old 02-05-2002, 04:31 PM
kwing kwing is offline
kwing is starting off with a positive reputation.
MAP Sensor
My 92 5.0 engine idles rough on cold winter days and throws out a bit of black smoke. The code I retrieved was 128 (MAP sensor vacuum line broken) but the vacuum was good. I also got a code 173 (running rich) probably as a result of the MAP code. I've reset the codes and replugged the MAP sensor and all seems to be well but I wonder if these things crack in cold weather or just wear out internally or could it be an intermittent bad electrical connection due to the cold?. How much to buy a new one?
Old 01-11-2003, 12:05 PM
njpeter njpeter is offline
njpeter is starting off with a positive reputation.
MAP Sensor
>out a bit of black smoke.....
Greeting all, my failing MAP sensor brought me here...now that I've confirmed what I though the problem is, I've gone ahead and found a used map sensor on ebyay for under $20, it's a $70 at the dealer.
my 3.0 v6 all of a sudden started to misbehave..wouldn't idle at all..at first..I unplugged the map ( i am really lame on ford FI, I've never had a problem and I was an import wrench before FI was even common) on a hunch that something was feeding the FI bad info ( this truck has been running well considering the age )..when I noticed the vac line going to it, i said "what the heck" and pulled the plug..boy was I shocked when the truck started and ran great..noticed the gas mileage was in the pits however. but the FI light wasn't on, and I don't have a code puller. I was going to try the reset of the ecu..but after reading yoru stuff, I decided to buy the sensor.
anyhow I'm glad to be here.
Old 01-11-2003, 03:54 PM
keith w's Avatar
keith w keith w is offline
keith w is gaining momentum as a positive member of FTE.keith w is gaining momentum as a positive member of FTE.
MAP Sensor
MAP pressure readings cowmilker08 1994.5 - 1997 7.3L Power Stroke Diesel 8 03-23-2009 12:46 AM
MAP sensor cowmilker08 1994.5 - 1997 7.3L Power Stroke Diesel 9 02-10-2009 04:21 PM
map sensor moritz1024 1978 - 1996 Big Bronco 15 03-27-2005 11:15 AM
question about MAP sensor scott9050 Aerostar 3 07-08-2002 07:08 PM
map sensor nmaineron Performance & General Engine Building 4 03-08-2002 02:07 PM
Tags
1987, 1995, 1996, 1999, 46, 73, bad, censor, f150, ford, location, map, sensor, truck, trucks, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
