1989 F250 C6 Transmission woes - Ford Truck Enthusiasts Forums
Old 01-15-2011, 06:28 AM
grizz3000's Avatar
grizz3000 grizz3000 is offline
grizz3000 is starting off with a positive reputation.
hey there,
So I fired up the ol' beast to plow the snow last week and behold my tranny is slipping like crazy.
I have looked through many results of different thread search attempts and found a few things to check (i.e vacuum, adjusting the band from the outside, etc)
However, I'm leaning to a rebuild. Why? The beast ran fine last fall and I decided to change the tranny fluid and filter. Yikes. I guess the 'crap' in the old fluid was helping the tranny limp along and create some friction/grip. Now, new fluid isn't so good for it in my humble opinion. (Note: I did not notice an abundance of metal debris in the pan when I changed the fluid/filter).
Anyway, do any of you have a good source for rebuild kits? I have done a few searches but haven't seen anything that matches what I need for the 89' F250 C-6 auto three speed.
The project won't start until after this snow season ends but I'm getting ready by researching and prepping. This will be my first tranny rebuild but I'm sure with a DVD, a good book, and a good rebuild kit, I can tackle it.
Thanks in advance!
Grizz
Old 01-15-2011, 08:07 AM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
Plenty of sources for rebuild kits, ebay.com or tciauto.com or wittrans.com or transtar1.com or for above and beyond, go to eatmyshift.com and click on Monster in a Box.
Old 01-16-2011, 01:16 AM
grizz3000's Avatar
Couldn't find anything for "street" machines at those sites. I'll have to wait until I get home to check E-bay (I can't stomach E-bay, but I have to wait until I get home to search it; the work PC won't allow us to go there)
Thanks,
Old 01-16-2011, 09:37 AM
tjc transport's Avatar
tjc transport tjc transport is online now
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
i know this sounds like a stupid question, but did you check the trans fluid level?? it may just need a quart or two .
Old 01-16-2011, 03:28 PM
razorback1957 razorback1957 is offline
razorback1957 is starting off with a positive reputation.
I have a F250xlt club/lwb with a 460. I am getting about 8 mpgs, any suggestion on
increasing the mpgs other that air/exhaust systems and has anyone seen much of an
improvement that has replaced exhause with a cat back and better air system.
Old 01-16-2011, 05:15 PM
Ohio Ford Farm's Avatar
Ohio Ford Farm Ohio Ford Farm is offline
Ohio Ford Farm is gaining momentum as a positive member of FTE.Ohio Ford Farm is gaining momentum as a positive member of FTE.
Wow to go from a C6 Trans problem to this.
Old 04-14-2012, 05:19 PM
gov2mod gov2mod is offline
gov2mod is starting off with a positive reputation.
I have a 87 F250 with 6.9 diesel and C6 transmission. A few years ago it lost 2nd gear. So I took off the pan and valve body to find the band was loose and the wedges fell out. I put it back to together and adjusted it and it worked fine until now. It lost 2nd again so I got back in it to find the band is worn out and out of adjustment. So, I need to replace the band and I understand I need to remove the transmission to do so. Is the band for the diesel C6 transmission different than a standard C6 band? Should I get the Kevlar band I see advertised? Other than a front and rear seal and the band, what other parts may I need to need to do this job?
Old 04-14-2012, 08:12 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
Since you'll be going through the trouble of dropping the trans, might as well do a full rebuilt.
Old 04-14-2012, 08:38 PM
I know I should but how much do I want to spend fixing up my beat up old 26 year old truck? The transmission pulled hard and shifted firm, never any slippage or other troubles until the band went. If I could change just the band without removing the transmission I would do just that.
Old 04-15-2012, 07:42 AM
You could replace it with a snap band without dropping the trans.
maybe do a search for info.
Old 04-15-2012, 07:52 AM
I've heard about the snap band but I don't know just how reliable they are. Have any of you ever used one? As for the regular band can anyone answer about them. Does the diesel C6 use a heavier duty band than a regular C6? Should I go with a kevlar band or is the "red" band sufficient?
Old 04-15-2012, 11:05 AM
I think all C6's were the same internally. The only difference was the vacuum modulator on the diesels.
Old 04-15-2012, 11:28 AM
OK thanks. I just didn't know if the C6 for the diesel used a heavier style band or not. What do you think about the kevlar band compared to the red one or standard band?
Old 04-15-2012, 11:30 AM
No idea, i've never rebuilt a C6.
Old 04-18-2012, 10:18 AM
Does anyone know about the using the Kevlar band compared to the red or standard band?
Tranny Fluid Change nflfreak43 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 38 07-09-2009 06:56 AM
89 F250 Vacuum line mystery grizz3000 1987 - 1996 F150 & Larger F-Series Trucks 0 05-12-2008 01:01 AM
Rhin-o lining or Line-x ???? grizz3000 Ranger & B-Series 13 03-30-2008 09:50 AM
Need replacement vacum line grizz3000 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 1 09-29-2007 11:57 PM
Tips on removing intake manifold???? grizz3000 1987 - 1996 F150 & Larger F-Series Trucks 6 07-22-2007 11:29 AM
Tags
1989, 350, 351, 460, 89, c6, f250, ford, rebuilt, specs, transmission, transmissions, transmisssion, truck, truk, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
