no power to stock cd changer, how to remove cds - Ford Truck Enthusiasts Forums
Old 01-14-2011, 11:07 PM
97flairside 97flairside is offline
97flairside is starting off with a positive reputation.
I replaced my stock headunit last year after it crapped out with a Pioneer. Not thinking, I never removed the 6 cds in it. Now I can't power up the changer to get the magazine out.
What can I do to get the magazine out or power it up? I dont have the clips for the radio to remove it. If I pull the panel off to get the changer out, is there any way to remove the magazine without power?
Old 01-15-2011, 06:47 AM
enriched&beyound's Avatar
enriched&beyound enriched&beyound is offline
enriched&beyound is starting off with a positive reputation.
dynamite works wonders...but drastically shorten the life both unit and CD's but at least they'd be out.
i would think that you could put some temporary power to your old unit to get the CD's out...couple of short pieces of wire, 1 for ground and 1 for power, attach one of each to your battery and the ground to case of the unit , the other to the power spade of the unit and try it
Old 01-15-2011, 06:58 AM
n5926g's Avatar
n5926g n5926g is offline
n5926g is starting off with a positive reputation.
Applying external power should do it,but you MAY need to supply the ground and TWO hots...One for the main radio B+ and the other to the "Memory" circuit.Both "Hot" lines can come from the same wire.Not sure if the memory circuit is needed,but it wouldnt hurt to supply both.
OR...IF you used an adapter cable to install the Aftermarket unit,just pull it,and plug in your old unit temporairily,get your disc,s,and then put the aftermarket back in......ooops...just reread your original post about not having the removal clips...you can make a couple with coat hanger..Ive done it many times before..got a couple sittin in my toolbox as I post.
Old 01-15-2011, 02:23 PM
original headunit is not possible. It completely crapped out and stopped working all together. There was nothing working in it. Thats why i got the pioneer installed. I almost wish I had found a used stock radio to replace mine.
Old 01-15-2011, 02:30 PM
GIGGER's Avatar
GIGGER GIGGER is offline
Posting Legend
GIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputation
Same thing sorta happened to me so I left the radio with a local stereo shop I trust & the next time they were doing a stereo in a truck like mine they plugged in my radio first then voila, out came the CD.
Expedition CD Magazine Changer Ejects Trionga 1997-2006 Expedition & Navigator 0 08-15-2015 09:09 AM
2005 Explorer CDs wont eject StephanieStroh Explorer, Sport Trac, Mountaineer & Aviator 1 09-20-2011 09:48 PM
help! cd's stuck in player xc4jokestomper Escape & Escape Hybrid 1 05-13-2011 03:39 PM
VIN# data base dudleygray 1997 - 2003 F150 3 01-03-2010 08:02 AM
cd changer problem polarisman Explorer, Sport Trac, Mountaineer & Aviator 3 10-10-2007 01:20 PM
Tags
1997, cd, cds, changer, f150, ford, location, magazine, magzine, power, radio, rear, remove, removing, removwe, stock, truck, without
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
