Tire Size 85 F250 - Ford Truck Enthusiasts Forums
Tire Size 85 F250
Old 01-14-2011, 11:30 PM
JayHenry JayHenry is offline
JayHenry is starting off with a positive reputation.
Tire Size 85 F250
I am sure this has been asked and answered before so I apologize, but Search is not my friend tonight. What is the maximum tire size I can install on a non lifted 1985 F250 4WD.I am thinking 33's (and maybe more) will fit just fine but I don't know about the width. I really don't want a real wide tire anyhow. I have the factory steel 16 inch wheels. Thanks in advance.
Old 01-14-2011, 11:39 PM
86bigred's Avatar
86bigred 86bigred is offline
86bigred is gaining momentum as a positive member of FTE.
i believe 33's are the max without a body,suspension lift or fender trimming.
Old 01-14-2011, 11:47 PM
TA Dave TA Dave is offline
TA Dave is starting off with a positive reputation.
The previous owner installed 35's on my 86 250 2WD. They will rub at 3/4 turns.
I have a set of 285's to install once the project gets going.
Old 01-15-2011, 11:52 AM
rockpile's Avatar
rockpile rockpile is offline
rockpile is starting off with a positive reputation.
I'm runnin 33x12.50r16.5's bfg all terrains they don't rub at all. When they wear out might go to a 34 or 35x9.50 mud terrain. But I have been pretty happy with my bfg's they ride well and have never let me down off the hwy. Too bad truck tires are so damn expensive, hope this helps.
1986 F250 4x4, 460, glass-pack, t-18, 10,000lb warn winch
1979 F150 4x4, 400, flowmaster, c6, 35" boggers "no lift"
Old 01-15-2011, 03:13 PM
04black5.4L's Avatar
04black5.4L 04black5.4L is offline
04black5.4L is starting off with a positive reputation.
im running 33x12.5-15 on my 84 f250 no rubbing good luck!
Old 01-15-2011, 03:23 PM
I have my eye on some 285/75R16's. It looks like they run out at 33.2 in diameter fit a 8" rim with a range of 7.5" to 9", and have a section width of about 11 and a half inches. E Range. Thoughts?
I believe those factory steels have an 8" rim width, is that so?
I do plan to lift the truck maybe 2 inches but the tires are going to have to come first and I want to keep the factory steels, they are in great shape. I also would rather not have to swap gears like I would need to do with significantly larger tires. I don't have any issues with leaving the factory gears as is with only going from a 32" tire to 33.2" but a bit wider.
I am more of a lurker than a poster but I do want to say thank you for a great resource.
Old 01-15-2011, 07:46 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
The factory rims are not 8 inches wide. The factory steel rims are only 6 inches wide. All those guys in the previous posts saying "there tires don't rub" can't be running the stock rim. It makes a big difference. A aftermarket rim is wider, and sets the tire away from the truck frame further which helps prevent rubbing.
Old 01-16-2011, 09:38 AM
OK then, second question. With the stock steel rims am I pretty much stuck with the 235/85R16 as a maximum size?
What should I look for regarding wider rims at the salvage yard, or on the aftermarket? I actually prefer the look of the plain steel rims on this truck but want slightly larger tires. I have no desire with this vehicle for fancy wheels.
Old 01-16-2011, 11:23 AM
00Boss's Avatar
00Boss 00Boss is offline
00Boss is gaining momentum as a positive member of FTE.00Boss is gaining momentum as a positive member of FTE.
I had 285/75s on the stock rims for some time and had never had a problem your safe in your set up. You could always go with a 16x8 painted wheel to.
Old 01-16-2011, 05:34 PM
Franklin2's Avatar
If you get too wide a tire on the narrow rim, it will wear the middle of the tire out before it wears the sides. I got a good deal on some 31x10.5x15 tires for my f150 because the guy I bought them from had them on a stock toyota factory rims, and the center was getting worn down some. They would still pass inspection easily in the center, and the outer edges were like brand new. I installed them on some cheap chrome rims that were 8 inches wide, and got a lot of life out of them.
You may run into this problem also if you get a tire that is too wide for your rim, even though it may not rub.
Old 07-06-2014, 04:36 AM
86f350's Avatar
86f350 86f350 is offline
86f350 is starting off with a positive reputation.
Reviving the dead but I just put 37x12.5r16.5 on 85 F250 yesterday. It is stock from the looks of it. I'll try to attach a picture.
Old 07-06-2014, 08:48 AM
Franklin2's Avatar
Quote:
No way that is not going to rub at some point on a stock no-lift truck. That's a huge tire. My 89 f250 has 35x12.50x16.5 but it has a 4 inch lift on it.
Tire help green_95 1999 to 2016 Super Duty 3 11-22-2015 09:18 PM
Will tire mismatch cause problems? blue76 Brakes, Steering, Suspension, Tires, & Wheels 2 06-09-2015 06:50 PM
F150 5.4L V8 vs. F250 5.4L V8 digruk Modular V8 (4.6L, 5.4L) 11 02-26-2015 09:20 PM
77 f250 sc stock tire size 4x4slik 1973 - 1979 F-100 & Larger F-Series Trucks 5 07-13-2014 09:03 AM
What Tires do you suggest? mrrish79 1987 - 1996 F150 & Larger F-Series Trucks 5 11-26-2013 01:42 PM
Tags
1986, 250, 30, 85, f150, f250, f350, fives, ford, lift, lifted, max, put, size, tire, tires, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
