Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 01-14-2011, 10:15 PM
ZeroTucker's Avatar
ZeroTucker ZeroTucker is offline
2004 Ford F-350
ZeroTucker is starting off with a positive reputation.
Fog Light Mod
Any of you Expy guys do a Fog Light Mod (fog lights stay on with high beams)?? I did this on my F250 and love it. My wife just got her 2007 Expedition and wants her fog lights to stay on with her high beams.
  #2 (permalink)
Old 01-15-2011, 08:58 AM
chuck s chuck s is offline
Garage is empty, add now
chuck s is starting off with a positive reputation.
I'd like to find a way to use them as day time running lights.
-- Chuck
  #3 (permalink)
Old 01-15-2011, 02:56 PM
TIKT B8 TIKT B8 is offline
TIKT B8 is starting off with a positive reputation.
I dont know and I have searched little but have found nothing. If you find it please post up. I did this on my old chevy and it took 5 minutes with a relay and worked great.
__________________
2007 Expedition Limited White Sand
  #4 (permalink)
Old 01-17-2011, 10:38 AM
ZeroTucker's Avatar
2004 Ford F-350
I really just need to get my hands on a wiring diagram and I could figure it out. On my F250, there is a switched ground (relay) that the high beams/fog lights share and only one set of lights can get the ground at a time. It was as simple as giving the fog lights a permanent ground so they operate independently of the high beams.
I love being able to utilize high beams with fogs, it really lights up the road at night and I still have the factory look of my truck.
  #5 (permalink)
Old 02-14-2011, 03:53 PM
xlt-sport's Avatar
xlt-sport xlt-sport is offline
xlt-sport is starting off with a positive reputation.
Quote:
-- Chuck
turn your headlight switch to the left and pull out.
you have fog light DRL's
  #6 (permalink)
Old 02-14-2011, 05:10 PM
Actually rotating right to the parking light setting (clockwise one click) and pulling out will illuminate the fog lights. And the parking lights, and side markers, and taillights, and instrument lights, etc. Don't want all the lights on, just the fogs.
-- Chuck
  #7 (permalink)
Old 02-14-2011, 07:51 PM
xlt-sport's Avatar
if you do as i suggest, you will have what you wished for.
turn **** LEFT.
the fogs [and fogs only] will come on with the ignition.
  #8 (permalink)
Old 02-15-2011, 06:28 AM
That's the position my light switch is in 99% of the time so the lights come on automatically at dusk. No fog lights until it gets dark enough for them all to come on. What am I missing?
-- Chuck
  #9 (permalink)
Old 02-15-2011, 09:41 AM
xlt-sport's Avatar
turn switch left and pull out.
if you have at least an xlt, with factory fogs. this will give you drl's
  #10 (permalink)
Old 02-17-2011, 05:32 PM
Doesn't work on my '07 XLT (with fog lights)...
-- Chuck
  #11 (permalink)
Old 04-03-2011, 01:27 AM
ExpeditionJim ExpeditionJim is offline
ExpeditionJim is starting off with a positive reputation.
Fog Lights On with Headlights in Daylight...Cover the Sensor
-- Chuck
I like full illumination in the daytime to be more visible to other drivers. I'm going to try covering up the daylight sensor with black vinyl and see if it lets me run my fog lights and headlights in the daytime.
  #12 (permalink)
Old 04-03-2011, 01:31 AM
Can someone please explain/document the modification for the 08 Expy to make the fog lights stay on (at night) when the high beams are on?
  #13 (permalink)
Old 04-04-2011, 09:07 AM
thinksnow thinksnow is offline
thinksnow is starting off with a positive reputation.
You guys are refering to a Brite Box
Innova Design & Distributing, Inc. - The Brite Box, Bulbzilla / Fogzilla, Diesel Turbo Lifesaver, Eclipse Sun Shade
  #14 (permalink)
Old 04-04-2011, 11:07 AM
Quote:
Originally Posted by thinksnow View Post
Hi ThinkSnow...
The BriteBox seems to be designed to turn on the lowbeam filaments when the highbeams are on.
I don't want that...I want my FOG lights to be on when my highbeams are on. Does the BrightBox do that?
Also, your application list does not include the 2008 Expedition. Do you make a BriteBox for that model?
UPDATE: ThinkSnow, I must have been looking at your old web site that I found by searching for "brite box" on Google. The applications page on your new site linked in your sig showed the BriteBox I need for my 08 Expedition with DRLs is the "Fogster 8.5.12" which I just found on Amazon for $99 and free shipping and no tax. I have ordered it. YAY!
I will also be installing 55 watt HID hi/low headlight bulbs and ballasts and 55 watt HID fog light bulbs and ballasts at the same time.
I won't be able to run the high and low beams at the same time because the HID hi/lo bulbs have a solenoid in the lamp that physically moves the bulb in or out relative to the reflector. But I WILL be able to have the high beam HID headlights and the HID fog lights on at the same time, which will be great!
I wish someone would make a true two-bulb HID unit (different than the HID/halogen unit) that would simply mechanically expose the already-on high beam HID bulb when the high beams are turned on. The high beam bulb would have to be on all the time because of the warmup period that is required for HID lamps. Of course this would require two ballast units per headlight, but that would be amazing to have the light from two HID bulbs on simultaneously at the high beam position! Hmmm, maybe I'll go down to TechShop (www.techshop.ws) today and start working on a prototype.
Thank you!
Last edited by ExpeditionJim; 04-04-2011 at 12:50 PM. Reason: Found new information.
  #15 (permalink)
Old 04-04-2011, 12:15 PM
Sorry, I don't want to mislead anyone. I don't sell these, I only knew of them because i had one on my 02 F250. Looking at the application guide it does list expys thru 2010 and does have a module that will turn on the low beams, high beams, and fog lights all at the same time; I think that is refered to as day light LOL.
http://www.innovadd.com/bb.app.guides/bb.apps.ford.html
Tags
02, 1996, 2011, duty, explorer, f250, fog, foglight, ford, light, lights, mod, park, super, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
