Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > 6.2L V8
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8 SPONSORED BY:
  #1 (permalink)
Old 01-14-2011, 07:50 PM
MDSuperDuty's Avatar
MDSuperDuty MDSuperDuty is offline
Garage is empty, add now
MDSuperDuty has a good reputation on FTE.MDSuperDuty has a good reputation on FTE.
Interesting info on Power Ratings for the new 6.2
I was looking on the Ford Fleet website and looking at: 2011 Ford Super Duty Pickup: Specifications and came across this
6.2L* 2-Valve V8 FFV (see the asterisk)
I followed this down to the end of the page and read
*385 hp and 405 lb.-ft. of torque under 10K GVWR. 316 hp and 397 lb.-ft. of torque over 10K GVWR.
So according to this an F350 would get a lower rated 6.2. Maybe a typo.
Here is the link if interested.
https://www.fleet.ford.com/showroom/...specs.asp?EV=0
__________________
2008 F350 CC, DRW, SWB, V10, 4x4 LEER Cap.
2002 Taurus (THE WINTER BEATER!!!)
2006 F250 Ext Cab, LWB, 5.4V8, 4x4 (traded 07/11)
2005 F150 Ext Cab, SWB, 5.4V8, 4x4 (traded 01/08)
1996 F150 Ext Cab, SWB, 4.9 I6, 5spd, 4x2 (Sold) This truck started it all!
  #2 (permalink)
Old 01-14-2011, 08:19 PM
If this is indeed truly the case, the 6.2 isnt that much better than the old 5.4, numbers wise for the over 10k trucks. I can't believe this would be true.
__________________
  #3 (permalink)
Old 01-15-2011, 11:10 AM
Does anyone know if there is any truth to this?
__________________
  #4 (permalink)
Old 01-15-2011, 11:55 AM
radzer0 radzer0 is offline
radzer0 is starting off with a positive reputation.
Im not 100% on this but i know ford likes to lower the power on there cab trucks. It could be for cab models ordered for utility bed, etc etc.
After all you can just get a diablo tuner or something to that nature and run in a performance tune for a regular truck. I dont see them doing anything other than programing diff.
  #5 (permalink)
Old 01-15-2011, 12:38 PM
countryboy69's Avatar
countryboy69 countryboy69 is offline
2011 Ford F-150
countryboy69 is starting off with a positive reputation.
I believe that they have the same power but use a different (lower rpm rating as opposed to max hp and torque) for over 10,000 lbs.
  #6 (permalink)
Old 01-15-2011, 01:00 PM
I've noticed they lower numbers for the cab & chassis but this is under the regular pick up section??
__________________
  #7 (permalink)
Old 01-15-2011, 01:11 PM
capn kirk capn kirk is offline
capn kirk is gaining momentum as a positive member of FTE.
its a government thing in the over 10k trucks. Same motor same power but the published numbers are lower
__________________
2011 F150 xlt ecoboost 4x4 screw 6.5bed added Firestone Ride-Rite airbags w/ hd compressor
Sold-1996 F-250 460 Super Cab 8' Bed 4x4 [/b]
3.73 limited slip frnt/rear, 35x12.50 BFG All-Terrain, 4" Skyjacker, 3" body lift, hedman headers 3" single-back turndown before rear axle, K&N Air Filter,rebuilt trans, deep trans pan, Warn manual hubs
  #8 (permalink)
Old 01-15-2011, 01:12 PM
I dont believe the fleet section shows the regular model trucks. Only the work models.
  #9 (permalink)
Old 01-15-2011, 01:17 PM
Quote:
Interesting
__________________
  #10 (permalink)
Old 01-15-2011, 01:19 PM
Well when you select the truck to spec out it allows for Ranger, 150, 250, 350, 350 chassis, 450 chassis, 550 chassis. But maybe its that. On that link I provided you can click on "Trucks" on the left column and see the available truck options.
__________________
  #11 (permalink)
Old 01-15-2011, 01:53 PM
On fords regular site even the 450 shows the full hp rating. Its only those fleet work trucks that are cut back.
  #12 (permalink)
Old 01-15-2011, 02:08 PM
Hmm. Well maybe that explains it.
__________________
  #13 (permalink)
Old 01-15-2011, 02:09 PM
scraprat's Avatar
scraprat scraprat is offline
2012 Ford F-250
My Garage
scraprat has a great reputation on FTE.scraprat has a great reputation on FTE.scraprat has a great reputation on FTE.scraprat has a great reputation on FTE.
This has been talked about here...
http://www.ford-trucks.com/forums/10...-question.html
__________________
2012 F250SD XLT 4x4 Supercab 158" 6.2, 3.73 Elocker, spray in bed liner
2008 F350SD XLT DRW 4x2 Supercab 158" V10, AUTO,4.30LS,tinted windows,spray in bed liner, Camper package, B&W Turnover Ball/Companion Hitch, SCT X3 by 5Star
2005 Carriage Cameo 32RLS
  #14 (permalink)
Old 01-15-2011, 02:20 PM
Quote:
Originally Posted by scraprat View Post
Thanks for the info!!
__________________
  #15 (permalink)
Old 01-15-2011, 04:34 PM
Crazy001's Avatar
Crazy001 Crazy001 is online now
2000 Ford Excursion
Crazy001 has a superb reputationCrazy001 has a superb reputationCrazy001 has a superb reputationCrazy001 has a superb reputationCrazy001 has a superb reputationCrazy001 has a superb reputationCrazy001 has a superb reputationCrazy001 has a superb reputationCrazy001 has a superb reputationCrazy001 has a superb reputationCrazy001 has a superb reputation
TomB985
Not quite.
It's the chassis/cab trucks as opposed to pickups. Because even the F350 chassis/cab is rated for a higher GVWR than the F450 pickup trucks. This puts it over 14,000 lbs, which puts it in an emissions category that requires a different emissions certification.
Attaining that requires the de-tuned PSD, but both the v10 and 6.2 are at their full designed horsepower.
On edit: Unfortunately due to government intervention the advertised horsepower ratings are now very misleading to everyone. I wish something was present on the Ford advertising literature that explained this better!
__________________
Tom,
2013 F150 XLT 4x4 EcoBoost
Moderators, Guidelines, and How They are Enforced
Tags
2011, 62, 62ford, 62l, f150, f250, ford, fords, gas, power, rating, ratings, reviews, specs, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
