Anyone heard of an Axiom / Ace Torque Converter?
Old 01-14-2011, 07:33 PM
strokerspeed's Avatar
strokerspeed
strokerspeed is offline
I'm going to be rebuilding my tranny in the near future and came across this torque converter on craigslist. Problem is...I can't find anything about this torque converter or brand on the net.
here is the ad description
"NEW Axiom/Ace Double locking Torque converter for Ford E40D/4R100. List price is 550.00 plus shipping will sale for 125.00 obo"
Any information would be greatly appriciated!
Old 01-19-2011, 06:45 PM
strokerspeed
No one? Guess that can't be good...
Old 01-19-2011, 07:34 PM
Damonkr's Avatar
Damonkr
Damonkr is offline
I bought a no name trip disc converter for my rescent rebuild on ebay from oregon performance transmission. It sucks!!! I can blow through the converter easy with my 80 hp tune. It is miserable until it locks. I fear Im gonna drop some cash to get a good one here shortly. Prob is I paid 600 for this one.
Old 01-19-2011, 10:03 PM
strokerspeed
ouch!
That just flat out sucks! Thanks for the heads up though...saves me from making the same mistake.
Old 01-20-2011, 12:02 AM
Damonkr's Avatar
Damonkr
Damonkr is offline
I am now looking at the banks converter and the stalion from precision industries. not sure which way ill go.
From my understanding it is all about the low stall for our diesels the clutch in mine holds once locked. The stator generates the torque mulitplication and is what you feel when you stand on the skinny pedal under 40 mph(tq lock)
Old 01-20-2011, 11:06 AM
strokerspeed
cool thanks for the information its greatly appriciated!
I notice your close to me...you didn't happen to rebuild your transmission yourself and have a transmission stand you want to rent out by chance do ya?
Old 01-20-2011, 11:14 AM
Ponyboychris's Avatar
Ponyboychris
Ponyboychris is offline
Hit it!
The Stallion Converters from PI is what Brian at BTS uses. Drop him a call to pick his brain.
Old 01-20-2011, 09:17 PM
Damonkr's Avatar
Damonkr
Damonkr is offline
Built it myself. (well it was my first and I had a friend that used to be a tranny man do most while I learned the process).
No tranny stand just a nice clean work bench and a parts bench to keep things organized.
Old 01-20-2011, 10:26 PM
strokerspeed
nice, any more helpful tips?
Old 01-20-2011, 10:50 PM
Damonkr's Avatar
Damonkr
Damonkr is offline
Clean everyting till it looks clean then clean it again.
If you plan on using an exhaut brake update to a 4 disc coast clutch and use the transgo tugger kit.
Also reybestos red clutches for more grab if you are runnig a tuner is nice. Soak them before installing.
Upgrade the forward clutch housing/drum to one that has splines all the way through it. I think it is the one specked for the E4od but they interchange.
Lock yourself in the garage alone when rebuilding and cleaning the VB's it takes a ton of concentration.
make friends with your local tranny shop. They usuall have all the hard parts in stock since they rebuild these trans all the time.
lastly dont cheap on the TC like i did.
Old 01-20-2011, 11:19 PM
strokerspeed
do you happen to know any good tranny shops I might be able to get those hard to find parts in lane county?
Thanks again, I sure appriciate all the advice!
Old 01-21-2011, 02:19 AM
johnbrown's Avatar
johnbrown
johnbrown is offline
Red face trans rebuild
Hi, Damonkr, i worked for a mechanic 50yrs ago and rebuilt his first tranny by lying it
ouy on a work bench that was about 40feet long one part a time,it was a Hydramatic.
I have thought about rebuilding e4od in my 95psd,the kits are reasonably priced
compared to what for a complete rebuild,is there a bunch special tools needed to pull
this off,as a side note my son and i had to replace adapter plate between engine and
tranny this tranny is heavy you almost need to eat bananas and your nunkels drag the
ground.
Old 01-21-2011, 07:57 AM
jwhitetail's Avatar
jwhitetail
jwhitetail is offline
For all you guys, PI is what i have, so far so good, note, make sure your trannies in top working order, the PI is a strong one, also if you can afford it change the flex plate to the billet one. JMOP.
Old 01-21-2011, 09:05 AM
Damonkr's Avatar
Damonkr
Damonkr is offline
As for special tools there are only two I think that you wont be able to do without. One I think was for compressing the clutches to install a snap ring and I can't recall the other but ill ask my tranny buddy. Both tools he had home built from previous rebuilds.
What was the reasoning for the new Flex plate? Just curious if I should look into one for when I order my PI stalion.
As for price to rebuild myself I am only in the rebuild $1550 (including the $585 for the junk convertor) but I upgraded a few things. If it were only a stock rebuild I would think 500 in soft parts is a good number to shoot for.
1972RedNeck
02-06-2014 04:57 PM
Stroker Ace
19
01-12-2008 02:30 PM
reecem13
18
10-01-2007 05:45 PM
BDalton
13
06-28-2007 10:02 AM
rocktestr
09-09-2000 12:56 PM
Quick Reply: Anyone heard of an Axiom / Ace Torque Converter?
