Clunk Coming From Rear Of Truck? Help!
Occasionally I get this somewhat loud clunk that comes from the rear of my truck. It is a 2002 F-350 Crew Cab 4x4 shortbed. The only time I hear the clunk is if I hit a big bump in the road or usually when I turn into or exit a steep driveway. It doesn't happen any other time. The clunk comes when the truck flexes from hitting the bump, or from turning into or out of the transition of a steep incline, such as a driveway or parking lot entrance. The clunk is definitely coming from the rear. Has anyone else experienced this, or something similar? Do you know what it may be? Is it normal? I'm thinking it could be a possible loose bed mount or cab mount but I haven't crawled underneath to check for myself. Anyway, I have an appointment to bring my truck in next Tues. to get it looked at but I figured I'd ask you guys first since many of you know more than my local dealer does. By the way, the trucks suspension is completely stock. I want to get this problem fixed before I install my lift kit.
Thanks,
Rich
Thanks,
Rich
I had a F-350 company truck that had a badly balanced tire. Had it balanced and the youngtster with the air impact tightened half the lugs. All I heard was whirr whirr whirr and didn't check it myself. Later in the week when I would turn into an incline or back up with the wheels turned it would pop. Made a sound like a ball joint that was real loose.
