what to do about wheel hop? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 01-14-2011, 01:04 PM
countryboy69's Avatar
countryboy69 countryboy69 is offline
countryboy69 is starting off with a positive reputation.
Hi guy's i got an 08 f-350 and i would like to eliminate the wheel hop. I was thinking about getting the deaver 5 1/2" lift springs and getting rid of the 4" block in the rear. would this eliminate the wheel hop or would i be better to go with traction/ladder bars? does anyone make a kit?
Old 01-14-2011, 03:13 PM
mwsF250 mwsF250 is offline
mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.
Depending on how stiff they are, the Deavers should certainly help.
But a well designed traction bar should be even more effective.
Old 01-14-2011, 03:17 PM
DAVE67FD's Avatar
DAVE67FD DAVE67FD is offline
DAVE67FD is gaining momentum as a positive member of FTE.
By wheel hop i assume you mean the typical SD bounce that occurs? Wheel hop is usually refered to the situation that occurs on take-off or under heavy braking at higher speeds. True wheel hop (as mentioned in the later) usually isn't considered much of a problem or a concern with the SD's. This is usually more of an issue with lifted trucks with larger tires that are used for off-road or competition and can be cured by the use of ladder/traction bars as you mentioned. If used for highway/road applications it can create a very harsh ride depending on how they are set-up, adjusted or used with other associated hardware.
If it's the more popular SD "bounce" you are refering to it can be difficult to eliminate and is a normal attribute of most pick-ups especially long beds. You can try experimenting with different tire pressures, loading the bed or changing spring/shock types and rates as you mentioned. These can also change the degree of true wheel hop as well. If you mainly use your truck for on road i would consider not using the bars or at least research several types for their expected performance and usage before purchasing.
Old 01-14-2011, 03:47 PM
maybe it is "bouncing". when i try to back up or go ahead in snow it does hop. i just assumed it was wheel hop where the leaves curve into a "s" and releases.
It is an extended cab long box, v-10 standard. so there is little weight back there. runs unloaded most of the time as well.
so would the blistein 5100 series shocks help. i was looking into these shocks.
Old 01-14-2011, 05:05 PM
redford's Avatar
redford redford is online now
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
Sounds like axle wrap.
Old 01-14-2011, 05:24 PM
HuntsDucks70's Avatar
HuntsDucks70 HuntsDucks70 is offline
HuntsDucks70 is gaining momentum as a positive member of FTE.HuntsDucks70 is gaining momentum as a positive member of FTE.
yup, its axle wrap. shocks could have minimal effect, if the valving were aggressive enough, but like other have stated, traction bars to eliminate it.
Old 01-14-2011, 07:02 PM
PsycoJuana's Avatar
PsycoJuana PsycoJuana is offline
PsycoJuana is gaining momentum as a positive member of FTE.PsycoJuana is gaining momentum as a positive member of FTE.
got a rear limited slip? on my 2002 it has a limited slip and can get like a bucking bronco, when dug in the snow. i have found it happens when im trying to get on it easy and spinning tires slowly or one that is. but if i just hit gas hard and get em to lock up and spin then no hop
bolt on ladder bars / anti-wheel hop? hail destroyer 1973 - 1979 F-100 & Larger F-Series Trucks 5 10-07-2016 10:53 AM
terrible wheel hop octaneforce 1987 - 1996 F150 & Larger F-Series Trucks 13 02-23-2011 08:07 PM
79 F-250 Supercab 4x4 vibration problem kdawg249 1973 - 1979 F-100 & Larger F-Series Trucks 12 01-27-2011 09:41 AM
wheel hop octaneforce 1987 - 1996 F150 & Larger F-Series Trucks 18 10-16-2009 09:34 AM
ridiculous wheel hop BigJake34452 1999 - 2003 7.3L Power Stroke Diesel 10 12-04-2008 01:41 PM
Tags
2009, 250, box, f100, f250, ford, fords, hop, hops, lifted, long, snow, spinning, truck, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
