1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
**Please help** P0306 CYLINDER 6 MISFIRE ISSUE
Old 01-14-2011, 08:50 AM
dav3455's Avatar
dav3455
dav3455 is offline
Hey guys, I have a 03 expo with a 5.4l engine, last night I started getting the misfire issue on cylinder 6, now my problem is that I just replace the serpentine belt last week and Im just a regular guy trying to save a buck on repair and do them myself. I dont have much experience but trying my best.
Now im thinking but can the misfire be due to replacing the belt? was I suppose to put it on a particular position like timing belts? not to sure. Any suggestion would be highly appreciated. Of course I was planning on taking the trip down to Disney in 2 month with all the kids but now Im a bit worried if the truck will have any issues.
Old 01-14-2011, 09:30 AM
bumparker's Avatar
bumparker
bumparker is offline
The serpentine drive belt is not clocked in anyway so that is not the issue. It sounds like you have a misfire due to a bad COP, cracked insulator or bad plug. My bet would be a cracked insulator. How many miles on the truck and when was the last plug change?
Old 01-14-2011, 09:39 AM
dav3455's Avatar
dav3455
dav3455 is offline
Thanks, I taught I replace the belt some how wrong
The truck has about 116k on it, I had the truck since about 100k and I have'nt change the plugs.
Old 01-14-2011, 10:04 AM
alloro's Avatar
alloro
alloro is online now
Received 4,196 Likes on 2,432 Posts
Originally Posted by dav3455
The truck has about 116k on it, I had the truck since about 100k and I haven't change the plugs.
The plugs get changed at 100K and it can cost anywhere from $400 on up to change them. The cost goes higher (and often does) if other problems arise during the replacement. It sounds like the previous owner traded it in just as all of the maintenance issues were coming up. I suspect you will have to change the spark plugs. While you're at it, have the lower ball joints inspected, they're likely due as well.
Old 01-14-2011, 10:09 AM
dav3455's Avatar
dav3455
dav3455 is offline
Thanks, is there any easy way to check if the plugs are in fact bad, just dont want to cough up 400+ for plugs and than come to find out it was bad coils or cranked insulator.
Old 01-14-2011, 04:27 PM
alloro's Avatar
alloro
You could pull out an inspect one or two of the easy to get to ones.
Old 01-15-2011, 09:37 PM
big poppa's Avatar
big poppa
big poppa is offline
I had a misfire too back some time and it was a bad plug, just changed all of them per the 100,000 mile Alloro spoke of. Also check to see if the boot to that sparkplug didn't pop out somehow, mine did and I just pushed it back down, alls good.
daveplot
06-20-2022 11:13 AM
DidieX
Modular V10 (6.8l)
15
03-04-2018 10:04 AM
Dillon Snyder
1997 - 2003 F150
03-09-2017 11:06 PM
Plumbin
09-24-2013 06:50 AM
ParisDakar
1997 - 2003 F150
08-23-2012 01:40 PM
Quick Reply: **Please help** P0306 CYLINDER 6 MISFIRE ISSUE
