How to bleed - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
How to bleed
Old 01-14-2011, 07:42 AM
RangerReb RangerReb is offline
RangerReb is starting off with a positive reputation.
How to bleed
I am servicing and 2008 Ford 6.4 diesel. Does anyone know how to bleed the air from fuel system after a filter change?
Old 01-14-2011, 08:37 AM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
did you cycle the key to just the on position, listen for the fuel pump to come on.
Wait at least 30 seconds then shut key off and repeat.
do this at least 6 times and then it should start.
If not then verify that you have both fuel filters on completely. Be care of the caps. There are torque specs on them.
If that does not work then you could always check the fuel cutoff switch to ensure it it no tripped.
Old 01-14-2011, 03:32 PM
mwsF250 mwsF250 is offline
mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.
Based just on the title of the thread, I was going to suggest replacing the serpentine belt. I usually manage to let at least a little blood every time I play with that.....
I am learning and wear mechanics' gloves on a more regular basis.
Old 01-31-2014, 11:08 PM
mrvega29 mrvega29 is offline
mrvega29 is starting off with a positive reputation.
Where is the fuel cut off switch on 2008 6.4
Old 01-31-2014, 11:11 PM
How do you bleed the system after replacing the fuel lines on a 2008 6.4
rear brake bleeding question dfoxengr Excursion - King of SUVs 19 09-24-2012 08:38 AM
how to bleed clutch on 85 f250 f100guy 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 02-18-2008 08:44 PM
bleeding clutch maverick76trucker Clutch, Transmission, Differential, Axle & Transfer Case 3 01-29-2008 10:43 AM
How to bleed clutch master and slave cyl? srumble 1994.5 - 1997 7.3L Power Stroke Diesel 4 11-17-2007 07:36 PM
how to bleed the clutch on my 1989 f-150 JustinGustafson 1987 - 1996 F150 & Larger F-Series Trucks 2 11-16-2006 02:42 PM
Tags
2008, 2011, 60, 64, 67, air, bleed, diesel, duty, f250, ford, fuel, super, system, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
