Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 01-14-2011, 02:40 AM
bozo4ford bozo4ford is offline
Garage is empty, add now
bozo4ford is starting off with a positive reputation.
Question 1986 Ranger 2.3 Replacement of Alternator belt???
Sorry that you keep seeing my name pop up a lot today,but that's what happens when you have 25 year old truck.
Ok. I've replaced my timing belt before, but the mechanic today noticed my alternator belt was cracked and ready to go. He wanted $90.00. The belt costs $15.00 @ Autozone. I never replaced this and wanted to know how difficult it would be. He only told me if I did it myself, I'd have to be really careful??? careful of what?
I bought this truck new back in '86, and it did not come with factory Air conditioning, but I had ARA install an after-market A/C about a year after I purchased the truck,which the A/C hasn't worked for years.
So is this an easy doable task? Thanks!
  #2 (permalink)
Old 01-14-2011, 10:18 AM
TigerDan's Avatar
TigerDan TigerDan is offline
1968 Ford F-250
TigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputation
I can't speak from experience of replacing this exact belt, but it's quite doable. I suspect the warning from your mechanic was to be careful of cutting into his profits by doing some of your own work...
If you replaced the timing belt yourself, you've already had to remove the alt. belt to get to it so you've done it before...
__________________
"alot" is not a word...
Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
Tags
1986, 2003, 2008, 23, 351, 86, alternator, belt, changing, cylinder, f250, ford, ranger, remove, replace, timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
