05 Transmission problems?
TRANS FAILURE
My 05 punched two holes in the top of the case when the reverse planetary snap ring let go. It failed without warning.
I think it happened when I was loading my camper. As some of you know; loading a camper takes several tries to get it on the truck straight. So pulling forward and backing up several times did it, I think.
I've heard that guys using snow plows have this failure also. reverse and forward several times with a plow will cause failure.
It took me awhile to figure out what was going on, because the transmission still worked fine, just had a pretty good leak coming from the top of the transmission. Matter of fact; I drove it to the steelership to have the trans replaced with a Ford Reman.
78K miles, not covered under warranty or recall.
