Truck began stalling while driving, now wont start. PLEASE HELP! - Ford Truck Enthusiasts Forums
Old 01-13-2011, 08:06 PM
dmayfieldusmc dmayfieldusmc is offline
dmayfieldusmc is starting off with a positive reputation.
Angry Truck began stalling while driving, now wont start. PLEASE HELP!
I HAVE A 2004 F250 6.0L SUPERDUTY DIESEL, THAT WILL NOT START NOW.
MY PROBLEMS BEGAN WITH SPITTING AND SPUTTERING, WHICH QUICKLY LEARNED THAT IT WAS AN EGR VALVE. EGR VALVE WAS REPLACED IN DECEMBER 2010.
SHORTLY AFTER THE EGR REPLACEMENT THE TRUCK STARTED STALLING WHILE DRIVING. MECHANICS HAVE NO IDEA, THERE ARE NO CODES WHEN TESTED. A FEW TIMES I HAVE HAD START UP ISSUES, BUT HAD GOTTEN GOING BY PUTTING IT IN NEUTRAL AND PUSHING IT BACK AND FORTH. NOW, IT WILL NOT START AND NO CRANK EITHER.
WITHIN THE PAST 6 MONTHS...I HAVE GONE THROUGH 3 SETS OF BATTERIES, 2 ALTENATORS, NEW FUEL FILTERS, OIL CHANGES, A STARTER, AND THE EGR VALVE.
CANT REALLY AFFORD TO TAKE IT TO THE DEALER AND MY VIN IS NOT INCLUDED IN THE RECALL FOR MY MODEL.
AT MY WITS END WITH FORD...READY TO GIVE IT UP, HELP!
Old 01-13-2011, 08:20 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
any codes?
how far have you chased power and grounds of the starting circuit. have you check the fuses yet?
Old 01-13-2011, 08:21 PM
gearloose1 gearloose1 is offline
gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.
Check fuel filters (both), and fuel pressure / volume...
Old 01-13-2011, 08:31 PM
Quote:
Originally Posted by cheezit View Post
any codes?
no codes havent chased power or grounds they looked good when i put new starter on and all fuses are good
Old 01-13-2011, 08:33 PM
Quote:
fuel filters are good, how do i check pressure/volume
Old 01-13-2011, 08:39 PM
cheezit's Avatar
there is no volume spec. only pressure. but with a truck that wont even crank over, testing that wont get you far.
when you checked the fues did you pull them out and look at them or did you use a test light? if the latter please do the former.
next have you tried to get the engine to crank by using the connector near the passanger side battery?
have you check for network communacation concerns? does the cig light work. is there power and ground at the dlc?
does the dash light up all the lights it should have?
Old 01-13-2011, 08:46 PM
all lights heater radio all dash lights work. DLC? and we looked at all the fusses. how do i crank engine by using connector near the passanger side battery?
Old 01-13-2011, 09:23 PM
bismic's Avatar
bismic bismic is online now
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
Quote:
There is a yellow with light blue striped coloured wire adjacent to the passenger side battery in the engine compartment, near the vacuum pump that has a "squeeze-and-pull" type connection. Disconnect it, and jump the male end of the connector to the passenger side battery positive terminal. The starter should crank when you do this.
Old 01-13-2011, 09:52 PM
High Binder's Avatar
High Binder High Binder is offline
High Binder has a very good reputation on FTE.High Binder has a very good reputation on FTE.High Binder has a very good reputation on FTE.
Oh that's cool thanks Bis. I'd rep ya but I'm still unable to rep you from the alternator thread.
Old 01-14-2011, 01:00 PM
NEMOTORCARS's Avatar
NEMOTORCARS NEMOTORCARS is offline
NEMOTORCARS is starting off with a positive reputation.
Sounds like the same issue we had with our 2005 6.0L, at first it would start when it was cold and when the engine heated up from driving 5-10 miles it would just die, problem got worse till it wouldn't start at all. If the 6.0L is not getting 500psi of oil pressure at all times it won't run. We had oil pressue when cold, but when it heated up it would drop under 500psi and die. The issue was a crack in the branch tube on the high pressue oil pump. A slight crack that got worse till it would not run at all. Not easy to check, but don't rule it out. We went nuts checking and testing everything till we found it and replaced the branch tube and it ran perfect.
When your EGR valve goes again, just delete it. It's one of the best moves we ever made on our 6.0L. We replaced an EGR @ 80K, 120k then it went again around 150k. We deleted it and now have 350k of hardcore 5th wheel trailer towing with no issues. Unless it is warranty, replacing and EGR is a complete waste of time and money. It took 3 to make it 150k miles, deleted it and then 200k of driving with no issues. Don't know anyone who has made it 200k on there original EGR.
Old 01-14-2011, 01:15 PM
I tossed the egr on mine... it looks original... had 230k on it when it electrically failed.
Old 01-14-2011, 01:25 PM
texans's Avatar
texans texans is offline
texans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to behold
There are plenty of members on here that have gone more than that on the original. I know I have mine deleted, but after looking back on it all, and more reading, I don't think I would do the same thing again. If it were me and my egr cooler went out (read I had 150k+ on my original stuff with no problems before I decided to delete) I would replace it with a bullet proff setup. That is what i'm recomending to all my friends and people on here now.
Old 01-14-2011, 01:37 PM
Do you tow at all?
Old 01-14-2011, 01:55 PM
texans's Avatar
yes I tow my 18k+ 5'er probably somewhere around 2-5k miles a year. sometimes more sometimes less.
Old 01-14-2011, 02:07 PM
We tow a 18k 50ft 3 Car trailer on a 5th every mile we drive. The only place the truck goes with out the trailer is the shop. We push it hard, 80-100k miles 5-6 days a week 11 plus hours per day. I think we have came across every issue you can have with a 6.0L.
P.O. blocked the egr valve... Now what Thedonk 1987 - 1996 F150 & Larger F-Series Trucks 1 06-04-2016 09:03 AM
1993 F350 5.8L EGR High Voltage Doc TeeRay 1987 - 1996 F150 & Larger F-Series Trucks 8 12-01-2015 02:36 PM
F250 6.0 stalls while driving Pch77 1999 to 2016 Super Duty 3 08-27-2014 04:41 PM
IAT vs IAT2 temperatures SHOOTER22250 6.0L Power Stroke Diesel 4 05-15-2013 07:53 PM
Truck stalled while driving and now it cranks but won't start exc4x4 Excursion - King of SUVs 6 04-09-2011 11:06 PM
Tags
1980, cranks, died, diesel, driving, electric, escape, f100, ford, navigator, running, screwloose, sputtered, stalled, stalling, truck, turn, v6, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
