1989 ford f150 302 to 351 swap
I just recently swapped my 302 for 351. I am using the 351 computer and distrubutor and fuel injector harness and they only thing that i havent changed over is the main wiring harness. The issue I am having is only 4 of they cylinders fire numbers 1,4,6,8. The other four are getting fuel and spark but not at the right times. The timing has been played with numerous times and is not the timing. The computer is refurbured from advance auto. Any suggestions?
on
H
Well I didn't do exactly what he did but something similar.What I did was swapped my 302 out with another 302.But the 302 that came out of my 93 f150 has the 154 firing order,the new motor has the 137 firing order.So what I did was put all the original fuel injection and wiring back on the new motor and got a computer out of a f150 with the 351 (137) firing order and it acts like it wants to crank but won't run.What it sounds like is wires mixed up or timing out of wack but we went over it numerous times.Any ideas?
on
You had something else mixed up then. Right now you have a computer/wiring mismatch so it'll never run right, so put the original computer back in and start from scratch with the plug wires. For the sake of eliminating a possibility try the old 1542 firing order on the plugs, it's always possible the motor isn't what you were told it was.
on
OK so I'm gonna assume it has a carb oriented cam in it which the EFI system probably won't like but it should at least try to fire. Is it making attempts to fire but just not catching? If so make sure the distributor is stabbed correctly but leave it lose enough to turn and while somebody cranks the motor turn the distributor until it fires up. If you really have to rotate the distributor around so the ignition module wiring is stretched all it can or is hitting the thermostat housing then it's off 1 tooth, pull it and carefully rotate it 1 tooth in the appropriate direction.
