1989 ford f150 302 to 351 swap - Page 2 - Ford Truck Enthusiasts Forums
Old 05-10-2014, 09:46 PM
JRS2's Avatar
JRS2 JRS2 is offline
JRS2 is starting off with a positive reputation.
Tman, if you had distributor off and have somebody crank engine with your thumb over spark plug opening, you can see where the pointer is when compression is evident .....
Old 05-10-2014, 10:01 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Quote:
Originally Posted by Tman589 View Post
To set the timing I put it 10 degrees BTDC on compression stroke and the rotor is pointing to number 1 on the cap which is pointing towards the rear of the engine correct?
Yes that sound right, can you verify your wiring against this diagram..
Old 05-10-2014, 10:41 PM
Tman589 Tman589 is offline
Tman589 is starting off with a positive reputation.
Ok got it to run (out of gas).But the only way it will start is the distributor turned all the clockwise,and the throttle wide open.But won't stay running on its own.
Old 05-11-2014, 08:32 AM
Conanski's Avatar
Ok got it to run (out of gas).But the only way it will start is the distributor turned all the clockwise and the throttle wide open
Your distributor is off 1 tooth, pull and restab it 1 tooth CCW. Was that with the 5.0 computer?
Old 05-11-2014, 09:58 AM
Yes with the 5.0 computer
Old 05-12-2014, 12:14 PM
Nothing's working guys..Im about ready to give up and put a carb back on it.
Swamping a 302 HO to a 92 F150. frankosd Engine Swaps 4 11-14-2016 11:09 AM
302 to 351w jlmills15 1978 - 1996 Big Bronco 8 10-20-2016 07:13 PM
88 302 to a 94 351.... C.B.Fiddler81 1987 - 1996 F150 & Larger F-Series Trucks 4 06-23-2016 10:48 PM
302 to 351 1996 f150 dozernsasha Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 19 02-12-2016 11:36 PM
351 swap into 302 1989 bronco blake70 1987 - 1996 F150 & Larger F-Series Trucks 3 03-24-2012 12:17 AM
Tags
1979, 1987, 1989, 1989ford, 1990, 302, 351, 351w, 93, conversion, f150, firing, ford, order, picture, swap, swapped
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
