6.9/7.3 IDI Diesel tech info - Page 5 - Ford Truck Enthusiasts Forums
  #61
Old 03-22-2015, 09:45 PM
Chevy_Eater's Avatar
Chevy_Eater Chevy_Eater is offline
Chevy_Eater has a very good reputation on FTE.Chevy_Eater has a very good reputation on FTE.Chevy_Eater has a very good reputation on FTE.Chevy_Eater has a very good reputation on FTE.
Fixed broken link, added another.
Quote:
Originally Posted by Chevy_Eater View Post
Compatability of ZF Gas 460 trans with IDI
ZF Transmission Identification, manuals, & diagrams
Useful Links
(IDI and related articles and files)
<big><big><big>Adding a Coolant Filter to the IDI Cooling System
</big></big></big>
IDI Coolant Filter Project
<big><big><big>6.9 vs 7.3 NA
</big></big></big>Rebuilding the International 6.9/7.3L Engine
Ford / Navistar Stanadyne IP Model #'s w/HP Ratings - Complete IDI Tuning Info
6.9L Injectors
(Good article on testing, removing, and cleaning the IDI injectors. Titled 6.9 injectors, but applies to the 7.3 as well.)
<big><big><big> </big></big></big>
  #62
Old 04-04-2015, 12:25 AM
Ford F834's Avatar
Ford F834 Ford F834 is online now
Ford F834 has a very good reputation on FTE.Ford F834 has a very good reputation on FTE.Ford F834 has a very good reputation on FTE.
Hydroboost re-seal write up
Write up and photo tutorial on how to re-seal the F450 Super Duty style hydroboost brake assist unit.
http://www.ford-trucks.com/forums/13...l#post15238532
  #63
Old 04-10-2015, 06:23 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
Quote:
Originally Posted by FORDF250HDXLT View Post
i dunno if this is posted here already or not,but in case not, here it is. pdf dl of the optional turbo idi diesel block of 93 & 94:
http://www.forddoctorsdts.com/downlo...eselEngine.pdf
29 Mb
updated link:
http://mid-atlanticema.org/wp-conten...sel-Engine.pdf
  #64
Old 06-01-2015, 11:27 PM
Installing Factory Tachometer in the 7th Gen F-Series
  #65
Old 07-13-2015, 07:54 PM
29 Mb
They moved it, again. Here's the current location:
Moves around more than Jimmy Hoffa.
  #66
Old 01-08-2017, 02:01 PM
fordtruckman838 fordtruckman838 is offline
fordtruckman838 is starting off with a positive reputation.
I didn't see it in the thread so I will post it up. Here is a good article from the Beru website on glowplugs.
http://beru.federalmogul.com/sites/d...gb_2014_fm.pdf
Glow Plug/gpr/hard Winter Start And White Smoke Thread 1997F-350 1994.5 - 1997 7.3L Power Stroke Diesel 222 02-01-2017 12:50 PM
6.9 idi review and info F-250 XL DIESEL 4x4 4 SPEED LOCK Leroy Unlisted Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 65 09-20-2016 12:02 AM
differences between early and late IDI glowplugs? volumetricefficiency Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 17 10-29-2009 11:55 PM
Tags
69, 6973, 73, 73l, diesel, faq, ford, glow, idi, low, plugs, power, reliability, remove, swollen
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
