6.9/7.3 IDI Diesel tech info - Page 4 - Ford Truck Enthusiasts Forums
  #46
Old 07-11-2014, 04:34 PM
Chevy_Eater's Avatar
Chevy_Eater Chevy_Eater is offline
Chevy_Eater has a very good reputation on FTE.Chevy_Eater has a very good reputation on FTE.Chevy_Eater has a very good reputation on FTE.Chevy_Eater has a very good reputation on FTE.
How to make your own glow plug wiring harness
Return Line Kit Install
camshaft for the IDI: "The torque cam" Typ4
IDI Oil Cooler Thread
Guide: DIY Tachometer Sender
Cheap Tach Sensor Replacement
Complete/guide: Accurate Custom Digital Tach.
  #47
Old 08-12-2014, 06:19 PM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
lets keep this thread for tech only. for BS or questions, open a new thread.
  #48
Old 10-17-2014, 08:51 PM
Red454sedgwick Red454sedgwick is offline
Red454sedgwick is starting off with a positive reputation.
  #49
Old 10-30-2014, 09:09 AM
Free downloadable TSBS and wiring diagrams LINK
Quote:
Originally Posted by FordTruckfan89 View Post
select your vehicle, and you can save to your computer as a pdf.
Search Wiring Diagrams
  #50
Old 11-22-2014, 10:05 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
the installation of the 2nd generation banks turbo sidewinder kit (w/instructions & detailed pics)
can't believe i forgot to link that here.oops.better late than never.oh,another one from log truck is the E40D shift kit.i put that in a devoted thread too.........
the installation of transgo's E40D-HD2-D reprogramming kit (shift kit)
  #51
Old 01-22-2015, 03:52 PM
bobross419 bobross419 is offline
bobross419 is starting off with a positive reputation.
  #52
Old 01-22-2015, 07:18 PM
More:
6.9L Info:
Quote:
Originally Posted by Ford F834 View Post
Check the SN...
Should look like this (but hopefully better numbers!) some rebuilders affixed a plate or re-stamped something there, but the OEM serial number should be like this:
Edit: as a side note, if you have bolt in oilers, be very careful not to loose the bolts themselves. They are special bolts. Misplacing the oilers or bolts will be expensive and a real headache to find replacements.
How Much Blow-By Is Too Much? <---- Important Read For New IDI Owners! Blow By Is Normal For an International IDI.
  #53
Old 01-26-2015, 02:59 PM
Burns3006's Avatar
Burns3006 Burns3006 is offline
Burns3006 is starting off with a positive reputation.
I was looking up the glow plugs the only ones that autozone, oreilly, KOI, and several others say that will fit are the ZD-11. Are they reliable? Are they the same as stock??
I hope im not the idiot that hasn't got a clue as to what im talking about. lmao!
if these are the ones to use for a 1999 ford f350 7.3L then the original post needs to be updated.
  #54
Old 01-26-2015, 03:09 PM
If that's not a typo and you indeed have a '99 then you have a Power Stroke and you're in the wrong sub-forum. This is the 6.9 & 7.3 IDI used in the '83 to '94 Ford trucks forum.
  #55
Old 01-26-2015, 03:40 PM
Burns3006's Avatar
Alright thanks man. i was wondering if i had read something wrong.
  #56
Old 01-26-2015, 09:56 PM
No problem.
  #57
Old 02-15-2015, 12:01 PM
Dan Pretto Dan Pretto is offline
Dan Pretto is starting off with a positive reputation.
cavitation confusion
Hello, I have a 1989 Ford E350 Club Wagon with 7.3 IDI diesel engine with 70,000 miles on it. In the new owners FAQ article you recommend using Extended Life Coolant (ELC) to help prevent cavitation. But in the linked article about cavitation, it explicitly says NOT to use ELC on older (pre-Powerstroke) IDI engines because some of the rubber radiator components may be damaged by ELCs. The article recommends using old style glycol antifreeze with low silicate. Please clarify. Thanks. Dan
  #58
Old 03-01-2015, 11:23 AM
IDI Won't Start/Hard To Start Thread
  #59
Old 03-01-2015, 11:24 AM
Quote:
Dan, you need to start a new thread with your question. This is the FAQ thread so you're not likely to get many replies here.
  #60
Old 03-10-2015, 08:39 PM
bentring bentring is offline
bentring is starting off with a positive reputation.
I was given the green light so here are a few links that will hopefully be useful to people.
Again, to my knowledge, all of these are specific to the 7.3 engines in the latter years of the OBS trucks.
The first three links are pdf files, and the rest are just single pictures.
E4OD Transmission Electronic Control Assembly in pdf
Writeup of a e4od to zf5 swap by Ceejmo from TDS
Information on the factory installed turbo 7.3 engine
Schematic of the glow plug system
Simple diagram of the 7.3 engine
Diagram of the selenoids and sensors on the 7.3 engine
Exploded view of the 7.3 engine.
Key for the exploded view of the 7.3 picture
6.9 idi review and info F-250 XL DIESEL 4x4 4 SPEED LOCK Leroy Unlisted Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 65 09-20-2016 12:02 AM
Glow Plug/gpr/hard Winter Start And White Smoke Thread 1997F-350 1999 - 2003 7.3L Power Stroke Diesel 388 12-29-2014 07:10 PM
PSD Part Numbers tjbeggs 1994.5 - 1997 7.3L Power Stroke Diesel 40 02-08-2014 11:10 AM
Tags
69, 6973, 73, 73l, diesel, faq, ford, glow, idi, low, plugs, power, reliability, remove, swollen
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
