6.9/7.3 IDI Diesel tech info - Page 2 - Ford Truck Enthusiasts Forums
Old 01-31-2013, 08:30 PM
Chevy_Eater's Avatar
Chevy_Eater Chevy_Eater is offline
Chevy_Eater has a very good reputation on FTE.Chevy_Eater has a very good reputation on FTE.Chevy_Eater has a very good reputation on FTE.Chevy_Eater has a very good reputation on FTE.
Here are pics & discussion on the ram/cold air mods:
Pics.
Discussion.
Old 02-01-2013, 05:34 PM
Here is an excellent tutorial with lots of pictures @ oilburners on IDI thermostat replacement:
THERMOSTAT REPLACEMENT 101 Tech PicTutorial
Old 03-03-2013, 01:58 PM
Soup Bowl Mod Explained, With Pics
Fuel tank sending units, pickup tubes, and bed removal:
Fuel Tank Sending Units
Show us your IDI:
Show off your IDI thread !!
STOP THE DOOR RATTLE
Old 03-17-2013, 11:53 AM
Old 03-27-2013, 11:25 AM
barely alive barely alive is offline
barely alive is starting off with a positive reputation.
6.9 IDI fuel pickup sending unit
Quote:
Originally Posted by BlueOvalBud View Post
This is common, the pickup tube off the fuel sending unit is made of rubber and disintegrates over time and the bottom rots off and falls to the bottom of the tank...the whole tube doesn't fall off, just enough that the truck will run out of fuel at 1/4 tank.
The fix: Cut a length of fuel hose that will fit over the pickup tube on the sending unit. Make sure the hose will reach the bottom of the tank. Not too long that it will turn back up like a J though, try to have it sit right at the bottom. Also, the end of the hose into a V so it won't suck itself to the bottom of the tank.
I have removed mine and this is what I believe has been done. See attached images:
First image shows the pickup and the second a close up of a part on the pickup line. Is this round thing above the attached fuel line a check valve? If so it must not work without the old foot at end of pick-up line as I see no way this prevents fuel from leaking back into tank since fuel does not flow thru the spring loaded valve. Is this anything to be concerned with?
Old 03-27-2013, 12:39 PM
That setup you have is factory, the '83s & '84s didn't have the cone of failure on them.
As I understand that check valve it allows the tank to continue to feed fuel should the pickup at the bottom become plugged or gelled.
Old 04-24-2013, 08:50 PM
Compatability of ZF Gas 460 trans with IDI
ZF Transmission Identification, manuals, & diagrams
Useful Links
(IDI and related articles and files)
<big><big><big>Adding a Coolant Filter to the IDI Cooling System
</big></big></big>
<big><big><big>6.9 vs 7.3 NA
</big></big></big>Rebuilding the International 6.9/7.3L Engine
Ford / Navistar Stanadyne IP Model #'s w/HP Ratings - Complete IDI Tuning Info
6.9L Injectors
(Good article on testing, removing, and cleaning the IDI injectors. Titled 6.9 injectors, but applies to the 7.3 as well.)
<big><big><big> </big></big></big>
Old 04-25-2013, 09:37 PM
I think all the mods are MIA.
Old 05-02-2013, 08:26 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
thanks cookie.
Maintaining Coolant
Coolant Filtration
Electric Cooling Fans
IDI Tuneup
IDI Dynamic Timing
Hydroboost Brakes
Performance Mods; Exhaust
Cowl Induction
Turbo
Intercooler
E40D FIPL/TPS
E40D Codes
7.3L IDI Turbo Diesel Engine Performance Specifications
some Niles already posted.im just unloading my sig here.carried them links around long enough lol.
Old 05-13-2013, 09:00 AM
Xenthrax's Avatar
Xenthrax Xenthrax is offline
Xenthrax is starting off with a positive reputation.
  #28
Old 05-13-2013, 05:17 PM
joshofalltrades joshofalltrades is offline
joshofalltrades has a good reputation on FTE.joshofalltrades has a good reputation on FTE.
one more thing this thread needs - how to add an electric fuel pump to solve hard starting from air intrusion problems. copied from another post where i just answered this common question
you are able to have both the electric and mechanical pumps installed, but ONLY if you have the electric set up so it only runs for a moment to prime the system, then turns off and lets the mechanical do all the work. thats how i have mine wired.
if you want to run the electric all the time, you must bypass the mechanical pump, or you run the risk of a pinhole leak in the mechanical allowing the fuel to be pumped into the crankcase, dilute your oil, and blow your engine.
now, here's a standard relay
so i'll give you some guidance here on how to wire it up for either way you want to run your pump.
1) pump always on with key on - must bypass mechanical pump
30 - fused battery power. i suggest connecting to the battery side of the starter solenoid, through a 10a fuse or circuit breaker
85 - ground - connect to a screw in the nearby sheet metal
86 - connect to FSS wire on top of IP.
87 - to pump
87a - not used
or you have an alternative wiring plan that i used. my e-pump is wired to run anytime the glowplugs are lit plus anytime i hold a pushbutton in the cab
2) pump runs momentary and may push fuel through mechanical pump
pushbutton will be a simple 2 wire unit which is on when pressed. this is the most common style and in electrical speak is SPNO (single pole normally open). it must be rated to carry the full load of the pump, which is usually less than 10a. that means you can't use that super-tiny one rated at 3a.
30 - to pump
85 - ground
86 - to glow plugs. i connected to the plugs side of the GP controller.
87 - fused battery power, as described above. also to one side of the pushbutton
87a - to the other side of the pushbutton
note that the pushbutton can be left out of this wiring plan, but is very helpful to have in the event you stall from air intrusion while running, change a fuel filter on a hot engine, or for some other reason need to run the pump at any other time than cold-start priming of the system. i added the pushbutton to mine after air intrusion got me after sitting at a store for half an hour and i had to crank on it for a long while.
for either plan, i recommend using 14ga wire for everything the diagram labels "high power", and 18ga for the relay coil wires, as they carry minimal power.
in my personal opinion, this second plan gets the best of both worlds. when i did this to mine, the mechanical pump was a month old and i didn't want to screw with it, so i read the warnings about having both pumps together (fuel in oil, etc) and decided to build it this way. its worked perfect for me for well over a year so far.
  #29
Old 06-08-2013, 10:11 AM
  #30
Old 06-23-2013, 04:52 PM
From AKAMacGyver, Timing With a Ferret:
Quote:
Originally Posted by akamacgyver View Post
Timing with the feret is pretty simple. Here is a video of the process, along with a video of how to adjust the timing.
Diesel pump timing - YouTube
Pump timing adjustment - YouTube
Good luck,
Mac.
Ferret Instruments V765-01 Injector Tester - Fuel System Tools
ID that IDI with Engine Number Location
6.9 idi review and info F-250 XL DIESEL 4x4 4 SPEED LOCK Leroy Unlisted Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 65 09-20-2016 12:02 AM
Glow Plug/gpr/hard Winter Start And White Smoke Thread 1997F-350 1999 - 2003 7.3L Power Stroke Diesel 388 12-29-2014 07:10 PM
PSD Part Numbers tjbeggs 1994.5 - 1997 7.3L Power Stroke Diesel 40 02-08-2014 11:10 AM
Tags
69, 6973, 73, 73l, diesel, faq, ford, glow, idi, low, plugs, power, reliability, remove, swollen
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
