Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Sign in using an external account
Register Forgot Password?
Welcome to Ford-Trucks Forums!
Welcome to Ford-Trucks.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Ford-Trucks Forums community today!
  #31
Old 08-03-2013, 09:53 AM
Chevy_Eater Chevy_Eater is offline
Chevy_Eater has a good reputation on FTE.Chevy_Eater has a good reputation on FTE.
Posting And You... | Flash Videos
Bleeding The IDI Clutch Hydraulic System.
  #32
Old 09-02-2013, 09:20 PM
Electric Diesel Primer Pump
Fuel Injector O-Rings:
McMaster-Carr Viton #111 o-rings
The IDI Myth Thread....
Harbor Freight Compression Tester that fits the IDI
Not IDI specific:
Marti Auto Works - Replacement Door Tags plus more
Cleaning your differential vent
  #33
Old 09-06-2013, 01:24 PM
Xenthrax's Avatar
Xenthrax Xenthrax is offline
Xenthrax is starting off with a positive reputation.
Xenthrax
Air intrusion addition
If your fuel heater is broken and letting air in your fuel, check out this thread
http://www.ford-trucks.com/forums/85...ns-w-pics.html
__________________
Drew H.
1988 Ford F-250 XL 7.3 N/A C6 tranny, Sterling 10.25 w/ 3.55 Gears Single cab. Estimated mileage: 358,000.
1988 Oldsmobile Cutlass Ciera 2dr 2.5 151 Pontiac Iron Duke - Estimated Mileage: Too much
  #34
Old 10-21-2013, 01:16 AM
lemonshindig lemonshindig is offline
lemonshindig is starting off with a positive reputation.
Dual Mass Flywheels:
"DMF for Dummies", by Talyn, shows the disassembly of a DMF and explains how it works and how it fails.
Midnight Mods: Dual Mass Flywheels For Dummies
The "Lucky Mod", to convert a DMF into a SMF.
Changing a DMF to a SMF
Where to buy single mass flywheel conversion kits:
Valair - (A preferred brand)
NMU70244 - Clutch kit, w/o flywheel ($287)
NMU70244-04 - HD Clutch Kit, w/o flywheel ($665)
V2127 - Flywheel ($222)
Performance Clutch - Ford PowerStroke
Luk - (A preferred brand)
07-225 (07-131FW on dial-a-clutch) - Clutch kit w/ solid flywheel (Roughly $600)
07-131 - Clutch kit for solid flywheel (Roughly $350)
LFW127 - Solid Flywheel (Roughly $250)
dialaclutch.com link
Southbend - (A preferred brand, uses Luk clutch)
1944325K
- Clutch kit w/ flywheel
1944325K-OK - Clutch kit w/ flywheel for modified engines (
375 hp, 800 ft lbs of torque)
Performance Luk Conversion
Google the part number to find vendors and prices.
Cheapbay options:
Perfection Clutch - "Brute Power 91200SK"
Perfection Clutch - "Zoom MU1989-1SK" I don't know what the difference is...
Brute Power:
and this one, brand unknown (Another member bought it and received an Luk clutch, w/ unknown flywheel) Fort Wayne Clutch & Driveline 1988~1994 - FORD F250,F350,F350 7.3L DIESEL w NON-TURBO/INDIRECT INJECTION - REPLACEMENT CLUTCH KIT w STEEL FLYWHEEL - 167325 - PN#(S) 07-131N, 07131N, KT07-131-N - F250-F550 - FORD - CAR & TRUCK ( CLUTCH KITS/ASSEMBLIES
  #35
Old 11-17-2013, 04:09 PM
Guide: DIY Tachometer Sender
International 6.9L Engine - Diesel Tech
The IDI Father Of The Power Stroke
Read more: http://www.dieselpowermag.com/tech/f...#ixzz2lZxivm00
ATS turbo .pdf files
Heim Joint Clutch Pedal Modification
Tech Help Files, DieselCare
ZF5 (S5-47) Transmission Rebuild
  #36
Old 11-18-2013, 07:17 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
Diesel Junkie
FORDF250HDXLT has much to be proud ofFORDF250HDXLT has much to be proud ofFORDF250HDXLT has much to be proud ofFORDF250HDXLT has much to be proud ofFORDF250HDXLT has much to be proud ofFORDF250HDXLT has much to be proud ofFORDF250HDXLT has much to be proud ofFORDF250HDXLT has much to be proud ofFORDF250HDXLT has much to be proud of
i dunno if this is posted here already or not,but in case not, here it is. pdf dl of the optional turbo idi diesel block of 93 & 94:
Click the image to open in full size.
http://www.forddoctorsdts.com/downlo...eselEngine.pdf
29 Mb
__________________
♠ Log Truck: '93 F-Super Duty (F450) XLT 1st Gen Navistar 444ci IDI Diesel w/ Intercooled 2nd Gen Banks Sidewinder Turbo, E40D, 5:13, Dually, 16' Dump & Auto Crane ♠
♠ Chip Truck: '93 F250HD XLT 4x4 1st Gen Navistar 444ci IDI Diesel w/ Intercooled 2nd Gen Banks Sidewinder Turbo, E40D, 3.55, Dually, 9' Dump, & Plow ♠
  #37
Old 12-01-2013, 12:30 PM
Rain water in/on that IDI? Replace that cowl seal!
LMC:
Truck Parts and Truck Accessories
Ford Part Numbers:
Quote:
Originally Posted by FORDF250HDXLT View Post
try searching for this online that ships or is in canada:
1980-1986 E5TZ1502824A
1987-1996 E7TZ1502824A
The IDI turbocharger thread...
7.3 fuel system upgrade
Members map
How to turn up fuel on 6.9/7.3 IDI
Quote:
Originally Posted by Chevy_Eater View Post
I prefer the simplicity of the manual pump myself, but if I was going to go the e-pump route I'd check into this discussion and group buy at Oil Burners on this carrier pump, looks like a nice setup for a good price:
Carrier Pump Group Buy
How to replace your mechanical fuel pump with a Facet Duralift electric fuel pump
  #38
Old 01-01-2014, 06:18 PM
MPoulson's Avatar
MPoulson MPoulson is offline
MPoulson is starting off with a positive reputation.
Since I can't find a diagram that shows it very well, I crayoned this one in.
The green lines are the returns.
You can see how an air intrusion problem could be difficult to find, if it's hiding in the green somewhere.
It is counter intuitive, when you look under the hood, to suspect the return lines and fittings of being able to fart up the whole system with bubbles.
But, when you look at it like this, it's pretty easy to imagine.
There really should be a sticky on the topic of the "zero tune".
It's suggested over and over again, that the injector return plastic thinggies, dozen + O rings, etc. be replaced and still, there are air intrusion questions like this one.
(No offence OPs. Your questions are totally legit.)
I think it's because it's hard to get your head around (looking down at the actual thing) why and how air could possibly get into the supply side of the system through the return lines.
Maybe someone who is smarter then me could write up a quick "how to zero tune the IDI".
__________________
It's probably fuel related! DIIIIVE!!!!
1994 F Super Duty Dump 7.3 NA ZF swap
  #39
Old 01-08-2014, 08:35 AM
Do I Have A Good Block? (6.9)
  #40
Old 01-30-2014, 01:36 PM
Tinstar36 Tinstar36 is offline
Tinstar36 is starting off with a positive reputation.
Also if it is not said yet the srater valve by the fuel filter needs a sealed valve cap mine was letting air by when I shut it off it starts much faster now I still need a new starter and batterys though
  #41
Old 01-30-2014, 08:17 PM
The group buy is over, but the pump is available here:
https://www.pegasusautoracing.com/pr...asp?RecID=9705
http://www.aircraftspruce.com/catalo...statepump2.php
Have a factory oil pressure dummy gauge? Turn it into a working real-world gauge:
http://www.ford-trucks.com/forums/12...l#post13986698
  #42
Old 03-10-2014, 06:41 PM
IDI Engine Wiring
IDI Injectors
  #43
Old 04-22-2014, 08:48 PM
C6 shifting early or late?
C6 VRV Adjustment Threads
LOW....L0w.....low Oil Pressure - Oil Pressure Regulating Valve
  #44
Old 06-05-2014, 11:40 AM
Can't get fuel in the tanks? Check out the filler neck vent tube.
Quote:
Originally Posted by Festus Hagen View Post
For the Injector Installation Kit installation You can follow Starmilts Humorous Fuel Return Replacement Procedure, I like to cut the 6 pieces between the Injectors to 4-1/16", Use a sharp razor blade to cut the hose and Vaseline to lubricate the o-rings.
For proper fuel system bleeding you can use steps 1 through 4 and 13 through 15 of the Fuel Filter Replacement.
-Enjoy
fh : )_~
  #45
Old 06-05-2014, 12:23 PM
Red454sedgwick Red454sedgwick is offline
Red454sedgwick is starting off with a positive reputation.
trf sedgwick
http://www.ford-trucks.com/forums/13...-breather.html
This is also a good way to fix it.
__________________
Clevenger 93 F250 xlt 7.3idit excab 4x4 5 by 3, always gets me where i'm going
Vince 88 F250 xl 7.3idit excab 4x4 E4OD banks 2, likes to leave me far from home
Tow truck 89 custom 7.3na dually c6, wont work somedays
White 95 F150 xl 302, 4x4 5 speed, always gets me home
toyoda 92 corrola auto, parts runner and the only one never to quit on me
Tags
69, 6973, 73, 73l, diesel, faq, ford, glow, idi, low, plugs, power, reliability, remove, swollen
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
the installation of the 2nd generation banks turbo sidewinder kit (w/instructions & detailed pics) FORDF250HDXLT Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 08-31-2014 06:16 PM
PSD Part Numbers tjbeggs 1994.5 - 1997 7.3L Power Stroke Diesel 40 02-08-2014 10:10 AM
Glow Plug/gpr/hard Winter Start And White Smoke Thread 1997F-350 1994.5 - 1997 7.3L Power Stroke Diesel 217 10-20-2013 08:12 PM
Glow Plug/gpr/hard Winter Start And White Smoke Thread 1997F-350 1999 - 2003 7.3L Power Stroke Diesel 386 11-26-2011 06:17 PM
Fuel tanks, 85-86 vs 87-89 ludis 1987 - 1996 F150 & Larger F-Series Trucks 9 09-01-2001 09:04 AM
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
vbulletin Admin Backup
