Exhaust in Cab? - Ford Truck Enthusiasts Forums
Exhaust in Cab?
Old 01-13-2011, 03:57 PM
BTyner41 BTyner41 is offline
BTyner41 is starting off with a positive reputation.
Question Exhaust in Cab?
Recently I have been smelling exhaust fumes in the cab of my truck when at a stoplight or parked in the driveway. When driving, the smell tends to go away. This occurs with the windows up and the climate control on auto. I can also smell this when I shut down the truck and exit. Has anyone else come across this situation? I am looking for anything that may be causing this. Hoping not to have to take it to the dealer.
Thanks,
Bryan
Old 01-13-2011, 06:28 PM
11350KINGRANCH's Avatar
11350KINGRANCH 11350KINGRANCH is offline
11350KINGRANCH is starting off with a positive reputation.
Put the climate control on recirculate and see if that makes a difference? I catch a faint exhaust smell every once in a while if the wind is just right and I do not have the climate control on recirculate.
Old 01-13-2011, 06:31 PM
pbruckne pbruckne is offline
pbruckne has a good reputation on FTE.pbruckne has a good reputation on FTE.
Bryan,
Sorry to say, but you're probably going to need to get that looked at by the dealer. Off-the-cuff guess, marmon flanges on the up-pipes that feed the turbo, egr feed tube or possibly exhaust manifold sealing at the head. These are high pressure joints, and could allow small amounts of leakage that would correlate with what you're observing. Nothing serious mind you for the most part, but needs to be looked at nonetheless.
-Paul
Old 01-18-2011, 12:33 PM
GRANTSBPACKING GRANTSBPACKING is offline
GRANTSBPACKING is starting off with a positive reputation.
I took my truck in for its first service at the dealer since they had offered the first oil change and urea fill at no charge. I noticed just what you are talking about on the drive home and decided to investigate once I made it in my garage. Low and behold, my oil fill cap was not tightened completely, pretty much just sitting there, and it was emitting a small stream of exhaust under the hood that I believe was getting sucked into the cab. Thanks dealer, I will handle my own oil changes and standard service from now on. (I have to anyways, egr delete). Not saying this is your problem, but worth checking. Good luck.
Old 01-20-2011, 09:40 PM
Thanks Paul that I was thinking that it might have something with the connections at the turbo as on my '04 I had to tighten soon after purchase. I will take to the dealer and see what they say this week.
Old 10-26-2011, 12:09 PM
Fat_Tire Fat_Tire is offline
Fat_Tire is starting off with a positive reputation.
Did you sort this out? I just started having the same issue.
Old 11-01-2011, 01:29 AM
f350newb f350newb is offline
f350newb is starting off with a positive reputation.
I have had this problem as well and took it to the dealer today. They could not find a reason. It has gotten so bad that it gives me a headache a couple of times. Im thinking that they left the cap loose but wont admit it, Guess I will wait and see if it does it again.
Old 11-01-2011, 10:54 AM
Quote:
I wonder if they checked the connection of the exhaust pressure sensor. This seems to be the leak that most of us have been having. Crawl under your truck from the passenger side just behind the front right tire and follow the exhaust tube straight up. At the very top you will see the exhaust pressure sensor tube and the nut that connects to the exhaust down pipe. If you lean up on a shoulder you might be able to get your finger on it. Look for soot around the connection. Many have reported the nut completely loose. Mine was... it wasn't even connected... I could spin the nut with my finger. If that is where its leaking you can tighten it yourself. Its tough to reach. You might have to pull off the tire and remove the splash cover to get a little more room to reach it. Or... take it back to the dealer and let them futz with it. Somewhere here or on one of the other forums is a pic of the connection.
Old 11-01-2011, 11:01 AM
Supposedly there was a TSB about that particular leak... 11-6-22 dated June 27, 2011.
Old 11-01-2011, 11:07 AM
EpicCowlick's Avatar
EpicCowlick EpicCowlick is online now
EpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud of
I re-checked mine last Saturday and found it still tightened properly. It is a LOOOOONG reach up in there but like others have said, it can be done pretty easily. The nut can be tightened with a 5/8ths wrench.
Old 11-01-2011, 05:02 PM
zonedar zonedar is offline
zonedar is starting off with a positive reputation.
I'm going to check my oil cap as I've had this problem too. However I seem to notice it when the truck is in the exhaust cleaning cycle and am at a stop light.
Old 11-29-2011, 03:11 PM
Hdslider's Avatar
Hdslider Hdslider is offline
Hdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputation
Quote:
Just to bring back up
Old 11-29-2011, 07:57 PM
SCORPIO26 SCORPIO26 is offline
SCORPIO26 is starting off with a positive reputation.
Mine just started to do this a week or so ago, always during a regen. In fact, its one way I can tell if the truck is doing a regen in traffic. I'm going to take it to the dealer for a check and probablly coolant test soon.
Old 12-03-2011, 09:23 PM
Thanks for this thread. Mine was loose and I was able to get it tightened up this morning. Long reach even for my long ams. Knew I was due for a regen. Took it out and no fumes.
Old 12-11-2011, 04:55 PM
MJZ MJZ is offline
MJZ is starting off with a positive reputation.
Holy mackerel, I need about 6" more length of arm. How did you get a wrench on this? Other than removing the wheel and liner, I don't see how you can tighten this, is there a trick I'm not coming up with?
Exhaust smell in cab PK150 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 08-21-2016 01:36 PM
Exterior exhaust smell overwhelming zmock8 6.0L Power Stroke Diesel 14 02-22-2014 03:47 PM
Diesel/Fuel smell in cab Stu206 1999 to 2016 Super Duty 6 01-10-2014 06:00 PM
Front seats bryan88 1966 - 1977 Early Broncos 7 02-05-2013 10:48 PM
Exhaust smell in cab mycol96PS 1999 to 2016 Super Duty 6 10-26-2011 01:31 PM
Tags
11622, 2011, 450, 67, cab, diesel, drive, exhaust, f250, faint, ford, fumes, smell, truck, tsb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
