08 console conversion - Page 4 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
  #46
Old 01-13-2011, 11:37 PM
DOConnor88's Avatar
DOConnor88 DOConnor88 is offline
DOConnor88 is starting off with a positive reputation.
I also did the '08 console swap in my '06. The only problem I have is not being able to put both armrests down. I can put mine down but the passenger is at a loss. Anyone know of a way to get a little extra space to allow both armrests to be down?
  #47
Old 01-13-2011, 11:59 PM
xmontex4's Avatar
xmontex4 xmontex4 is offline
xmontex4 is a name known to allxmontex4 is a name known to allxmontex4 is a name known to allxmontex4 is a name known to allxmontex4 is a name known to allxmontex4 is a name known to all
Im not sure exactly what could be done but I have heardbof people trying to remove their arm rests im not sure if you want to do that or not
  #48
Old 01-14-2011, 12:30 AM
Lubbockguy1979's Avatar
Lubbockguy1979 Lubbockguy1979 is offline
Lubbockguy1979 has a good reputation on FTE.Lubbockguy1979 has a good reputation on FTE.Lubbockguy1979 has a good reputation on FTE.
My idea would be to slot the seat bolts to allow them to move 1/4 od a inch or so twards the driver and pasenger doors. I just leave the arm rest up in my truck. If I could only train the wife to do the same.
  #49
Old 01-14-2011, 06:20 AM
xmontex4's Avatar
Lol, does the paint rub or scratch off easy?
  #50
Old 01-14-2011, 08:05 AM
xmontex4's Avatar
also how far back does the console go compared to my current one its the 40/20/40 console and ive got a subwoofer box that touches the back will the other console be set back or with it be fine?
  #51
Old 01-14-2011, 10:06 AM
Zmann's Avatar
Zmann Zmann is offline
Zmann has a very good reputation on FTE.Zmann has a very good reputation on FTE.Zmann has a very good reputation on FTE.
I pulled my armrests off ,,, the console is more comfortable andI had to flip the armrest up everytime i used the belt release
I can't tell you how far back a stock would go I made those spacers to put my further back and up a little
  #52
Old 01-14-2011, 10:39 AM
As you see in the pics my husky floor mats still fit so pretty close to stock.
  #53
Old 01-14-2011, 02:53 PM
xmontex4's Avatar
ok, i shouldnt have a clearance issue then, if i want to move its position where could i get spacers that do that?
  #54
Old 01-14-2011, 05:38 PM
Zmann's Avatar
A machinist
  #55
Old 01-14-2011, 09:57 PM
WorkhorseF250's Avatar
WorkhorseF250 WorkhorseF250 is offline
WorkhorseF250 is starting off with a positive reputation.
just wondering if anyone here that has done the conversion has the middle seat? would love to do that kinda conversion but i have a Super cab so not sure if it would work
  #56
Old 01-14-2011, 09:59 PM
Zmann's Avatar
? I think it's an option in the 08super cabs also
the best part is you don't have arm rest .. the other items should be the same
  #57
Old 01-15-2011, 12:00 AM
Waltdog's Avatar
Waltdog Waltdog is offline
of American machinists
Waltdog has a good reputation on FTE.Waltdog has a good reputation on FTE.Waltdog has a good reputation on FTE.
This is a cool mod I may have to get a console
  #58
Old 01-15-2011, 12:38 AM
DOConnor88's Avatar
Quote:
Thanks a lot for the suggestion. Im probably going to give that a try. But as long as my armrest is working then thats all that matters I guess.
  #59
Old 01-15-2011, 08:27 AM
Angrywasp Angrywasp is offline
Angrywasp is starting off with a positive reputation.
Quote:
Just got back from GA with the console and that might be a fairly big issue. Mine has cupholders in the front AND the rear which makes it about 5 inches longer than the consoles without the rear cupholders. That puts the front of the console pretty much in the front dash if you move it forward enough to clear your sub box since it touches the current center seat.
  #60
Old 01-15-2011, 08:42 AM
Zmann's Avatar
the rear cupholder version is rare /
I wouldn't be slotting seat mounts ,, in a wreck you want it exactly as engineered .. could you imagine the seat comming loose in a wreck ?
plus it looks difficult because of the way brackets locate in the center of the stud
03 bench seats switch to captains? Jointasset 1999 to 2016 Super Duty 0 09-18-2016 10:13 AM
Center console swap?? mtmatzf150xlt 6.4L Power Stroke Diesel 10 07-01-2013 10:57 PM
2008-10 Center Console in 2011 40 oz 1999 to 2016 Super Duty 2 10-28-2012 09:54 PM
Captain Chairs with Console Conversion RRS540 1999 to 2016 Super Duty 5 07-30-2010 11:22 AM
Center Consol gui88ford 2004 - 2008 F150 8 12-31-2008 12:50 PM
Tags
05, 08, 2011, cab, console, conversion, diesel, duty, f250, ford, oklahoma, owned, pre, seat, super, swap
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
