For those on the darkside, what headers?
Yes I realize that it's Taboo to talk darkside her but I have to work with what I have! I have a 1987 TPI 350 in my 1953 F100 (pictures in my gallery). Its hooked up to a 700R4 sitting on a Fatman Fabrication MII front suspension. MII power steering and a CPP steering column. That brings us to the heart of the question...what headers will work? Any suggestions...Please.
Mark
Mark
Mark
Mark
If you think it might help I'll try to take a few pictures with the headers in place on my engine. It might give you an idea as to whether they might work.
Drew
Don't be bashful about darkside stuff. There's a pretty good relationship on this forum between the restoration guys and the darkside guys and we all can play in the same sandbox without anyone getting hurt feelings.
Here's what I was going to run on my Caddy;
But, due to some steering issues I had to go with the stock exhaust manifolds (for now -- someday I'll get it all worked out)
I think if you go with a set of shorty headers for a sbc, you'll be ok
Bobby
Bobby
Received 4,132 Likes
on
I'm using Sanderson # cp11 headers on my sbc the 3cp10's should work as well. They are a shorty type header that dump out the back by the firewall. Mind you I'm deeper toward the darkside using a Chevy C10 frame as well. http://www.sandersonheaders.com/Sand...eader-Set.html
on
No problems on the darkside here as that is how I roll. Mine is a S-10 frame so I have to use swap headers. In your case I think I would take a minute and contact fatman and ask if they had experience with this. They do a lot of swaps so they just might have heard of a fix.
jim
jim
I've got some Hedman headers for a '81 Camaro on my '56. It's Camaro-clipped, but the motor is moved forward about an inch from stock location to clear the firewall. The headers fit fine and clear everything, but one of the tubes was slightly dented to allow for removal/clearance of the Upper control arm cross-shaft bolts. I couldn't find a part number on the headers, but I looked at a friends '78 Camaro and his new Hedman headers are nearly identical to mine.
Vette1976
13
06-25-2017 09:17 AM
dave boley
56
03-10-2012 08:59 AM
hwyhogg
02-22-2010 06:04 AM
