2002 F150 4.6 Cylinder 8 Misfire - Ford Truck Enthusiasts Forums
Old 01-12-2011, 10:15 PM
biebs53 biebs53 is offline
biebs53 is starting off with a positive reputation.
My buddy has an 02 f150 Screw 2wd and after a day of mudding he had a code that came up cyl 8 misfire. I assume its the coil but what else could it be? And what needs to v6 e removed to change cyl 8 coil? Looks like fuel rail is in the way.
Old 01-13-2011, 06:44 AM
torkum's Avatar
torkum torkum is offline
torkum is gaining momentum as a positive member of FTE.
Chances are that the spark plug hole got water in it and is causing the problem. You can take the coil out with out removing the fuel rail, just rotate it. Don't pull the plug until you are sure the hole is free of water.
97 f150 cyl 3 4 7 8 misfire. Help Dillon Snyder 1997 - 2003 F150 6 03-09-2017 11:06 PM
2013 6.2 strange misfire problem johnno5 6.2L V8 4 12-27-2016 05:03 PM
99 v10 miss problem zakarehamrick Modular V10 (6.8l) 3 06-27-2012 06:01 PM
Dtc 0350 - 0362 skoveng Modular V10 (6.8l) 10 10-29-2008 07:07 PM
97 4.6 Misfire in#3, EGR Flow Insufficient., coil? mitchymitch 1997 - 2003 F150 29 03-11-2004 07:15 PM
Tags
2002, 2003, 2007, 46, 46l, 99, cyl, cylinder, engine, f150, ford, misfire, misfiring, piston, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
