Standalone Engine Management System
Check out this place. They can probably help you.
http://www.dunne-rite.com
Otherwise there is:
http://www.sdsefi.com/
http://www.atlanticspeed.com/product...idcategory=132
http://www.autotrendefi.com/accel_dfi_emic.html
http://www.electromotive-inc.com/products.html
http://www.bigstuff3.com/
Or there is also megasquirt if you are more of a do it yourself type.
Otherwise there is:
Dunne-Rite Performance
Otherwise there is:
Simple Digital Systems EM-4
FAST 301000 XFI Standalone EFI Control Unit - Wideband Air / Fuel Tuning - Atlantic Speed Warehouse
Autotrend EFI - Authorized Accel/DFI EMIC
Electromotive Products
BigStuff3.com
Otherwise there is:
BigStuff3.com
Thanks for the help.
I am using the stock ECU and wiring harness in my truck. I just got a custom tune from a local mustang specialist to take off all the emissions stuff and fuel pump and things that im not running in order to get rid of the check engine light. but if I was going to change from an ECU to a standalone I would go with the Mega squirt system. its not that hard to strip the stock harness, I got everything from a Crown Vic
bhenders
01-12-2017 09:22 PM
mustangmike6996
08-21-2015 06:57 PM
