2004 FORD 6.0 F250 DIESEL WONT START - Ford Truck Enthusiasts Forums
Old 01-12-2011, 08:11 PM
killthe6.0forddiesel's Avatar
killthe6.0forddiesel killthe6.0forddiesel is offline
killthe6.0forddiesel is starting off with a positive reputation.
Angry 2004 FORD 6.0 F250 DIESEL WONT START
P0046/P0098/P0107/P0113/P0198/P0237/P0405/P2285/P2623/U0155/P0670/P0683
ALL DO TO LIFTERS SPINNING PUT IN ALL NEW LIFTERS,CAM,LIFTER
KEEPERS,NEW HIGH PRESSUER OIL PUMP 1 YEAR A GO,6MONTHS A GO OIL
COOLER,EGR, WAS REPLACED NEW NOW LIFTER SPUNN BECAUSE KEEPER BROKE
NEW HEAD BOLTS AN GASKETS FRONT COVER REPLACED AN WATER PUMP MAIN
OIL PUMP ALL NEW STILL WILL NOT RUN
PLUGGED IN OBD2 AN ALL THESE CODES CAME BACK I THINK THAT THE FICM OR
PCM ARE BAD. NEED A REAL DIESEL MECHANICS HELP.
AFTER ALL THIS MONEY I HAVE SPENT I WANT TO PUT A BIG STICK OF TNT AN WATCH IT GO BOOM!!!!!!!!!!!!!!
Old 01-12-2011, 08:34 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Moved to the 6.0L Powerstroke Diesel forum.
Old 01-12-2011, 08:44 PM
gearloose1 gearloose1 is offline
gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.
I ain't touching this one.
I AM IN THE DIESEL SECTION
Old 01-12-2011, 08:48 PM
Quote:
You are now.....before you were in the Super Duty forum. You said you needed a real diesel mechanic's help and you're more likely to get the help you need here since your problem is engine specific.
Old 01-12-2011, 08:50 PM
READY TO BLOW THE FORD UP
WHY NOT I HAVE DONE EVERY THING RIGHT I HAVE WORKED ON THIS TRUCK
FOR 2 WEEKS STRAIGHT I PUT THE CAB IN THE AIR 2 DIFFERENT TIMES I MADE
SURE EVERY THING WAS PLUGGES IN I HAVE TORQUED IT EVERY BOLT 4 TIMES
I TRIED TO START FOR 30MINS WHAT ELSE IS THERE? INJECTORS WILL NOT
SPRAY EXHAUST PIPE HAS NO SMOKE I SPRAIED STARTER FLUIED ON AIR
CLEANER AN IT WAS THE ONLY WAY IT WOULD HIT AN STILL NO START
DOUBLE CHECKED ALL WIER PLUGGINS 10 TIMES
CAN I PLEASE GET SOME HELP?
Old 01-12-2011, 08:54 PM
SHOULD I BLOW IT UP?
Old 01-12-2011, 08:58 PM
bismic's Avatar
bismic bismic is offline
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
Begin by looking up your codes here:
2005 Update Page 07 Diagnostic Codes P0046 thru P0275
They are ALL electrical short or open circuit codes. Did you short out anything when doing the work? Are your PCM connectors on tight? Cable insulation all good? What about fuses / relays?
Old 01-12-2011, 09:01 PM
SteveBricks's Avatar
SteveBricks SteveBricks is online now
***** Emeritus
SteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputation
If you do blow it up, please take some video
Seriously though...relax. We'll try to help you.
Is yours an early or late model '04?
Old 01-12-2011, 09:07 PM
MORE LIKE THE LATE MODLE OF THE 2003
Old 01-12-2011, 09:10 PM
OK THANKS FOR THE CHART YOU SENT WILL START IMMIDATELY IN THE MORNING
Old 01-12-2011, 09:22 PM
I HAVE OWNED THIS TRUCK FOR 3 YEARS I HAVE ONLY DROVE IT 6 MONTHS I GOT IT AN
THE HIGH PRESSUER OIL PUMP WAS BAD I PAID 1200 TO HAVE IT REPLACED THEN THE OIL
COOLIER WENT OUT ABOUT 3 MONTHS OF DRIVING IT, IT DROPED ABOUT A GALLON OF
WATER NO IDEA WHERE IT WENT THE OIL COOLER CRACKED BECAUSE OF THAT
THE MECHANIC AT FORD SAID IF I REPLACE THE OIL COOLIER THAT THE EGR WILL BE
SOON SO I PUT BOTH IN BRAND NEW AND THE LIFTER KEEPER BROKE AFTER DRIVING IT
FOR 3 MONTHS I KEPT HEARING A MISS FOR THE 3 MONTHS IT WAS ONCE IN AWHILE
I KNOW IT KEPT SPINNING AT IDLE FINALLY IT SPUNN AN THE BEARING WENT OUT ON
THE LIFTER IT TOOK ME 2 DAYS TO TAKE IT A PART AN ANOTHER DAY TO GET THE
LIFTER OUT I KNEW IF 1 HAD A PROBLEM THE REST WOULD BE SOON SO I PUT ALL NEW
LIFTERS,KEEPERS,AND CAM I PUT IT TOGETHER AN IT STILL DID NOT RUN I COMPLETLY
CLEANED FROM TOP TO BOTTOM INSIDE MOTOR I DID NOT KNOW THE MAIN OIL PUMP
WAS IN ALUMMINUM FRONT COVER I NEW SOME METAL HAD WENT THROUGH IT AN IT
WAS SLOW FOR THE OIL PRESSUER TO COME UP BUT THAT SHOULD NOT KEPT IT FROM
RUNNING I READ ON THE INTERNET INSUFFIENT OIL FLOW WOULD STOP IT FROM
RUNNING SO I PUT A NEW OIL PUMP AN FRONT COVER OIL PRESSUER COMES UP RIGHT
AWAY IN 8 TO 10 SEC.
Old 01-12-2011, 11:54 PM
m-chan68's Avatar
m-chan68 m-chan68 is offline
m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.
No offense intended. But if you're posting on a public forum requesting assistance, PLEASE remove your CAPS LOCK first and foremost. Second, please take the time to read over your post carefully to ensure that there are no grammatical or spelling errors in your post BEFORE you click that "submit reply" button. This would ensure that your post is easier to read and understand what you are asking. I can appreciate the level of frustration you must be feeling right now, because I can't imagine the amount of money you have spent in parts just going by what you've listed so far.
Now that we have that out of the way, let's start with some basic things to check before we dig deeper than needed. When you cycle the ignition key to the RUN position, do you hear the injectors buzzing/pre-cycling as well as the hum of the fuel pump? When you remove the secondary fuel filter cap and cycle the key to the RUN position, does fuel fill up the secondary housing RAPIDLY and overflow within seconds or does it just struggle to rise and then bleed back down as soon as the key is turned to the OFF/LOCK position?
Do you have access to a scan tool that can read live data? If so, what are your readings when you select ICP volts, ICP psi, ICP psi desired, IPR duty cycle, FICM_L, FICM_M, FICM_V, FICM_SYNC, RPM and B+? I am asking what you see in readings at key-on/engine-off AND while you crank the engine over. Can you run an injector buzz test? If so, are any codes set? Even if no codes are set, do you hear ALL EIGHT injectors buzzing/clicking, or are some missing in action (EVEN IF IT PASSES THE BUZZ TEST)?
I suspect the answers to any one of the above questions will lead you into the direction you need to be, to get your engine started. Looking at your list of codes at a quick glance leads me to believe your P2285 and P2623 are likely the cause of your engine not starting.
Old 01-13-2011, 03:22 PM
Ok sorry about the miss spelled words an caps I am literate so I do the best I can.
i have worked on it all morning wiggling plugs I checked both oil an diesel filter reservoir they both where empty I turned the key on an off 2 times the diesel fuel came up an over flowed immediately oil reservoir was dry till starting an it filled up very fast 6 to 8 seconds had oil pressure open filter reservoir was full I ended up braking diesel filter cap and had to go buy another one someone had over torqued before me an was very hard to screw on an off so I went to take it off the half inch ratchet slot broke I had to take a punch an hammer an beat it off the little steal rod in the middle broke will that stop it from running or have any other causes it broke above first seal second seal gone I hear fuel pump on frame coming on an i hear some small motor in front of driver side make a funny sound rummm rumm rumm some other motor on passenger side comes on an stays on for a 1 or 2 goes off an dose not come back on for awhile I do not hear nothing from the motor an no injector buzz at all wiggled most plugs while turning key on an off took one injector plug off put volt tester on it all 4 pins positive negative straight to battery could not get no reaction i have access to OBD2 no way of hooking up live data scanner
how do you run an injector buzz test. We have figured that much from the 2 codes an the chart played with all the wire's an i noticed one plug was in backwards put it in right dose not seem like it helped at all. Is there any way I can find a live scan tool I can use with out paying for it. Thanks for your help once agin. Plug to high pressure sensor an regulator are plugged in right an regulator was replaced 2 years ago right before I got the truck. The EGR recycled relay is updated to new as well.
Old 01-13-2011, 03:38 PM
The map sensor an main fuel pump are brand new put on just before I bought the truck. The mechanic shop that the previous owner took it to hin picked the guy saying that this part map sensor is bad replaced it an said the fuel pump was bad replaced it then they said that the EGR was bad so replaced that $900 dollars later it still did not run he took it to Ford an they said it was the high pressure pump an it would be $1500 dollars more to fix it. I bought the truck from him i put an OBD2 to it an it said that the cam sensor was bad so I replaced it still did not run I paid tow bill to take it to nozzle master an high pressure was 500 psi mechanic at Ford said it needs 1300 psi to run so I put it in new the mechanic I paid to replace it took the oil coolier off thinking it was like the 7.3 the pump was in the front we found the high flow screen was shredded so put it in new to after he was done it cranked up right away an ran great I want to know is there a proper way of bleeding the high pressure oil rail I know after I tore the whole motor a part there was no oil in them an it would take awhile to bleed them fuel injectors seem not to work at all I clean the high flow reservoir the high flow screen was fine but had some metal pieces on it so I cleaned it very good. Thank you once agin for your time. head gaskets an bolts are brand new too.
6.0 Rough Idle/Start When Cold P0270/P0271/P0272/P0277/P0278 hotdogpimp 6.0L Power Stroke Diesel 15 02-16-2016 12:54 PM
351 Windsor Build Micbruff 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 23 11-05-2014 09:17 PM
Error Codes: P0341, P2258, P2287, P2614, P2617 gesb123 1999 to 2016 Super Duty 0 10-29-2014 09:46 AM
Bulletproof Diesel Oil Cooler INSTALL -Snake- 6.0L Power Stroke Diesel 46 11-06-2012 06:33 PM
comp cam noisy Jeff92f150 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 21 01-28-2008 01:38 PM
Tags
2004, 2005, 60l, deisel, diesel, duty, f150, f250, f350, fire, ford, international, start, super, truck, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
