2004 6.0 FICM, NEED HELP - Ford Truck Enthusiasts Forums
Old 01-12-2011, 06:59 PM
UGA25 UGA25 is offline
UGA25 is starting off with a positive reputation.
I just recently had my truck in for head gasket replacement. $4700 later I have a new truck it seems, complete with ARP head studs and a Hypertech tuner that has improved fuel mileage beyond 19 MPG!!!!!
All is great................ Except, I apparently now have a FICM that is going bad. Can someone tell me what the signs are of the FICM going bad. I am told that cold weather starts are a sign, and I had a heck of a time getting it to start the last few mornings with the weather in the 30's.
Also, what will it hurt to drive it that way for about a month until the funds are recovered froom the above mentioned....
thanks in advance for any help guys...
<!-- / message -->
Old 01-12-2011, 07:36 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Moved to the 6.0L Powerstroke Diesel forum.
Old 01-14-2011, 09:34 AM
amadas350's Avatar
amadas350 amadas350 is offline
amadas350 is starting off with a positive reputation.
mine at start up would be blowing black smoke initally. you could rev it up and kind of had skipping feel about it. about being strapped for cash, i was the same way. tech in virginia (that just replaced my egr/oil cooler) told me if i got aFICM he would reflash if for free, but i was leaving for ga the next day. i chanced it, and ran it for another month. it finally went south and would not idle.
new ficm $425+$160 flash
Old 01-14-2011, 10:06 AM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
Check the 6.0 tech folder at the beginning of this forum for the FICM test procedure. It can be done with a DVOM and a little help from a friend to turn the key. Anything below 45v and you have a bad FICM.
Old 01-14-2011, 10:24 AM
NEMOTORCARS's Avatar
NEMOTORCARS NEMOTORCARS is offline
NEMOTORCARS is starting off with a positive reputation.
Signs are Hard Starting, Shaking and Missing at idle dumping out Black Smoke, Loss of Power. The truck will seem like it is running on 4-6 cylinders and skipping. We have a 2005 Ford F250 6.0L with 350k miles and we are on our 3rd FICM.
Old 01-14-2011, 10:45 AM
da-bees da-bees is offline
da-bees is gaining momentum as a positive member of FTE.
Quote:
Did you replace the FICM at first sign of trouble each time or did you continue to drive it ( how far ) one or more times? How many injectors have required replacement ?
Old 01-14-2011, 11:21 AM
We just replaced it each time, it was cheaper that way for us because we run the truck runs interstate on a weekly basis. If it goes down on the highway and we need to get towed with a 5th wheel trailer its twice the cost of the FICM. First time, we replace 2 injectors, 2nd time 1 injector and the last time none. The issues is if you don't just replace it this motor is so fn sensitive you just end up blowing injectors and make a $500 issue $2,000 quickly.
No start have pids, Need Help BDell82 1999 to 2016 Super Duty 1 06-21-2016 08:00 PM
list of things dealer said I need Gun-Driver 6.0L Power Stroke Diesel 8 02-16-2016 01:25 PM
Coolant in FICM? jlalum 6.0L Power Stroke Diesel 14 11-30-2015 03:36 AM
05 Excursion No Start.. Scanner wont link for code CenCalGuns 6.0L Power Stroke Diesel 7 03-11-2014 06:17 PM
Help no logic input voltage going into ficm togie 6.0L Power Stroke Diesel 15 08-29-2011 06:53 PM
Tags
04, 2004, 2005, 2006, 60, bad, black, dumping, f250, ficm, ficn, ford, located, missing, powerstroke, smoke, symptoms, tess, test
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
