What year did 8 lugs change - Ford Truck Enthusiasts Forums
Old 01-12-2011, 06:49 PM
MADFord4X4's Avatar
MADFord4X4 MADFord4X4 is offline
MADFord4X4 is starting off with a positive reputation.
Does any one know what year the 8 lugs went from 8X6.5 to 8X170mm.
I am looking for a set of 8 lug rims in a whole size like 16X10 or 17X10.
I have a 1973 F250 Highboy and I am running 33X12.5X16.5, I was told that 15" won't fit they hit the brakes or tie rod or something.
Thanks,
Mike
Old 01-12-2011, 06:51 PM
impalaslayer's Avatar
impalaslayer impalaslayer is offline
impalaslayer is starting off with a positive reputation.
98 i think or 99, when ever the body style changed
Old 01-12-2011, 06:55 PM
thechief66's Avatar
thechief66 thechief66 is offline
thechief66 is gaining momentum as a positive member of FTE.thechief66 is gaining momentum as a positive member of FTE.
It was for the 99 model year (which actually came out in 98). 97-older 250 & 350 have the 8 on 6.5" bolt pattern.
Old 01-12-2011, 06:56 PM
NMCinNYC's Avatar
NMCinNYC NMCinNYC is offline
NMCinNYC is starting off with a positive reputation.
Yeah, when the Super Duty body style came out. 99 and up are the 170mm bolt pattern. Anything on 97 and prior model years will fit your truck.
650's Avatar
650 650 is offline
650 is starting off with a positive reputation.
I think it was 98 they changed. Also on my 1976 highboy my 16in. wheels just barely clear the callipers and there is no way 15`s would fit it. Your 73 has drums on all four corners? If so I would think 15`s might fit it.
Old 01-12-2011, 06:59 PM
MADFord4X4's Avatar
Thanks for the information.
Yes my 73 has drums but I would like to change them to disk and power steering in the near furture, so I am trying to plan ahead and get larger rims if I need to and it looks as though I do.
Old 01-12-2011, 07:02 PM
MADFord4X4's Avatar
Would Chevy 8 lugs fit my 73 if they are off of the same year like 97 and down?
Old 01-12-2011, 07:04 PM
650's Avatar
650 650 is offline
Chevy wheels will fit. Also for the calipers you could get a 76 front axle and just bolt it in.
Old 01-12-2011, 07:05 PM
NMCinNYC's Avatar
Somebody correct me if I'm wrong, but if you go to something that would fit Chevy, I think it would have to be from 1987 or earlier. In 1988 Chevy went to the independent CV joint... But it was complicated, because they continued to build "old body style" heavy duty trucks until like 1991... So to answer, if you got an 8-lug Chevy, it would have to be for a Chevy that actually had a front axle...
Make sense?
Old 01-12-2011, 07:11 PM
MADFord4X4's Avatar
That is a good point. I am always leary of mixing parts, but I thought wheels would be easy. Figures nothing ever is.
Old 01-12-2011, 09:51 PM
RustyHighboy RustyHighboy is offline
RustyHighboy is starting off with a positive reputation.
Chevy wheels often have a smaller center hole and will not fit over ford hubs.
Old 01-12-2011, 10:46 PM
earthquake68's Avatar
earthquake68 earthquake68 is offline
earthquake68 has a very good reputation on FTE.earthquake68 has a very good reputation on FTE.earthquake68 has a very good reputation on FTE.
Quote:
This is the actual problem. To the best of my knowledge, Chevy didn't go metric on the 8 lugs like Ford, but the center hole is small and WILL NOT fit over the hub. You can put a Ford wheel on a Chevy, but you can NOT put a Chevy (or Dodge) wheel on a Ford.
For the record, they make 8 lug, 15" wheels with a large center. They bolt right on a Dodge with no modifications. For Chevy, you have to shave the calipers down a little so they fit. For Fords, you have to run drum brakes. They won't fit on disc brake axles.
We used to do A LOT of mix and match when we were into wheelin' every weekend.
Old 01-13-2011, 12:16 AM
MADFord4X4's Avatar
Thanks I have heard that before and forgot it. Fords will fit others but others will not fit the Ford.
Of course!
Old 01-14-2011, 04:06 PM
vman vman is offline
vman is starting off with a positive reputation.
I ran a set of the factory wide steel wheels off a chevy on my 77 f-250.I did have to torch the hole out a little bit on the back wheels.Question,Does anyone know if the 8 lug vans went metric also?I'm looking at a set of wheels on craigslist and the guy said he had them on a 2000 chevy van and a 2004 ford van???
Old 01-14-2011, 05:12 PM
jaceharp jaceharp is offline
jaceharp is starting off with a positive reputation.
The vans (E150-350) still use the old 8-6.5 bolt pattern all the way up to current model year.
5 lug 16.5 rims (9) mrcman58 Ford Truck Parts for Sale 9 03-01-2016 11:36 PM
New 16 Inch X 8 Lug for 65 F250 sobz 1961 - 1966 F-100 & Larger F-Series Trucks 8 02-08-2015 11:52 AM
Wheel help 49f3dls 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 06-16-2013 07:18 PM
8 Lug 16.5 in rims Redneck1465 WTB - Parts & other 17 03-01-2013 05:14 AM
Show up pitures of your 8 lug rims 8X6.5 4x4 MADFord4X4 1973 - 1979 F-100 & Larger F-Series Trucks 6 01-17-2011 01:18 AM
Tags
1973, 1999, axle, change, date, drums, f250, ford, front, have, lug, lugs, pattern, truck, year
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
