96 f-250 diesel power steering problem - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 01-12-2011, 06:28 PM
fordservicetrk fordservicetrk is offline
fordservicetrk is starting off with a positive reputation.
hello
i have a 1996 ford f 250 diesel i am having problems with the power steering i have good power steering turning to the left and virtually no power when turning to the right ????
Old 01-12-2011, 09:35 PM
craftsmangary's Avatar
craftsmangary craftsmangary is offline
craftsmangary is starting off with a positive reputation.
Well I think your problem is in the steering gear because you have good pressure from the PS pump to turn left and the pressure doesn't know left from right. I would still make sure all your ball joints are not seized and u-joints if its a 4x4. You should be able to get a reman gear for less than $200, that would probably be the best way to go.
Old 01-14-2011, 01:42 AM
johnbrown johnbrown is offline
johnbrown is starting off with a positive reputation.
Hi,my son's 1995 psd snapped the pitman arm off at the gear box while sitting in our
garage and all he was doing was turning steering wheel,got a reman from O'RIELLY'S
used to be SHUCK'S for about $150.00,then to make sure we deserved it the adapter
plate on bellhousing broke at the starter this happen in the same garage maybe hexed.
Power Steering Problem cassell1 1973 - 1979 F-100 & Larger F-Series Trucks 6 02-19-2015 12:48 PM
Another Power Steering Question brunobrunoruch 1999 to 2016 Super Duty 0 11-15-2014 01:54 AM
F250 power steering problem MyBabyCopper 1973 - 1979 F-100 & Larger F-Series Trucks 2 12-12-2012 11:53 AM
Power Steering jerks to left or right ch435 Brakes, Steering, Suspension, Tires, & Wheels 4 06-11-2011 06:32 PM
05 F250 Diesel - P/S leak at hydro boost ktootall Brakes, Steering, Suspension, Tires, & Wheels 3 08-26-2005 01:52 PM
Tags
05, 250deisel, 96, binding, broblems, diesel, f250, ford, gear, hard, power, problem, problems, starting, steering, turning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
