How Long Will a New Battery Last with Bad Alternator - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 01-12-2011, 05:00 PM
StangPullerF250 StangPullerF250 is offline
StangPullerF250 is starting off with a positive reputation.
My truck is stranded at Target and I really don't feel like getting it towed. I want to get a new battery anyways since its over 8 years old. If the alternator is bad, can I make it home from a 30 minute highway commute? I know dumb question, I would just rather replace the alternator at home (if that is the problem) than trying to do it in the dark at Target.
Old 01-12-2011, 05:05 PM
Byram's Avatar
Byram Byram is offline
Byram has a good reputation on FTE.Byram has a good reputation on FTE.
Remember the more electric you use - the quicker it will die.. Headlights, Blower motor, radio etcc....
jim6liter's Avatar
jim6liter jim6liter is offline
jim6liter is starting off with a positive reputation.
you'll make it.Don't use your headlights and keep the stereo off.
Old 01-12-2011, 05:12 PM
Lubbockguy1979's Avatar
Lubbockguy1979 Lubbockguy1979 is online now
Lubbockguy1979 has a good reputation on FTE.Lubbockguy1979 has a good reputation on FTE.Lubbockguy1979 has a good reputation on FTE.
I made it about 2hrs a truck with a bad altenator. The 05+ gasser and the 6.0 + trucks will shift really erratically if the voltage gets low just a fyi.
Old 01-12-2011, 05:29 PM
seminaryranger's Avatar
seminaryranger seminaryranger is offline
seminaryranger has a good reputation on FTE.seminaryranger has a good reputation on FTE.
Yeah, you should be fine to make it 30 min with a fresh battery.
When installing it, I'd supplement it with a jump from whoever is giving you a ride. In other words put the battery in your truck, connect everything, and hook up a set of jumper cables to another running vehicle while you start it. This will give you a little extra juice to make it home.
While you're driving home, minimize all electrical drain.
No stereo.
No electric windows.
No fiddling with the electric seats.
No headlights in daytime.
No HVAC
The truck's computer and auto transmission use a fair bit of juice just to operate the necessary functions needed to keep the engine running and transmission shifting.
You should be fine.
Old 01-12-2011, 05:40 PM
99f350sd 99f350sd is offline
99f350sd has a good reputation on FTE.99f350sd has a good reputation on FTE.
I would say it will be close as new batteries usually don't have a full charge..
Old 01-12-2011, 08:24 PM
FYI I made it home. I think it just needed a new battery. I'm going to see if it starts in the morning. Thanks Everybody.
Old 01-12-2011, 08:29 PM
BobbyDiesel71's Avatar
BobbyDiesel71 BobbyDiesel71 is offline
BobbyDiesel71 has a very good reputation on FTE.BobbyDiesel71 has a very good reputation on FTE.BobbyDiesel71 has a very good reputation on FTE.
please check both batteries! Diesels needs two fresh units with a working alternator.
Have them load tested, one good battery will be drained by bad battery
have alternator tested as well. Most new alternator will have a lifetime warranty
Old 01-12-2011, 09:02 PM
gearloose1 gearloose1 is offline
gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.
Reserve capacity is always posted for a new battery, but the test load is probably less than your actual load.. so do some calculation:
Battery Tutorial
Quote:
Cold cranking amps (CCA) is a measurement of the number of amps a battery can deliver at 0 F for 30 seconds and not drop below 7.2 volts. So a high CCA battery rating is especially important in starting battery applications, and in cold weather.This measurement is not particularly important in Deep cycle batteries, though it is the most commonly 'known' battery measurement.
CA is cranking amps measured at 32 degrees F. This rating is also called marine cranking amps (MCA). Hot cranking amps (HCA) is seldom used any longer but is measured at 80 F.
Reserve Capacity (RC) is a very important rating. This is the number of minutes a fully charged battery at 80 F will discharge 25 amps until the battery drops below 10.5 volts.
An amp hour (AH) is a rating usually found on deep cycle batteries. If a battery is rated at 100 amp hours it should deliver 5 amps for 20 hours, 20 amps for 5 hours, etc.
If you have a 50 amp load (600 watt) typical of a diesel with nothing else on... no ac no lights, etc...
You have the minutes battery says... less about 25% based on state of charge and error ....
Old 01-12-2011, 10:11 PM
CraigOutdoors's Avatar
CraigOutdoors CraigOutdoors is offline
CraigOutdoors is gaining momentum as a positive member of FTE.
I've been told that a bad battery will kill an alternator and vice versa. I know that I have had a battery go bad and the alternator went suspiciously soon thereafter a couple of times. Confirmed both were bad with testers, not the replace and hey now it works method. To be on the safe side, you might pull the alternator and have it tested just to see. All the parts shops around here will do it free.
Old 05-05-2011, 11:16 PM
mavrik4x4 mavrik4x4 is offline
mavrik4x4 is starting off with a positive reputation.
At least 20miles@3am coming home from the bar. With the last 5mi w/out headlights. Enjoy!lol
2 New Batteries and New Alternator Still Voltage Issues 651_F350_KR 6.0L Power Stroke Diesel 38 04-26-2016 10:01 AM
charging and starting jle70 1994.5 - 1997 7.3L Power Stroke Diesel 8 10-06-2014 10:23 PM
2006 Ford F350 Super Duty Alternator Problem BGH21 1999 to 2016 Super Duty 4 10-17-2012 07:46 PM
Alternator / No Charge? Paladin921 1994.5 - 1997 7.3L Power Stroke Diesel 27 08-09-2010 10:03 PM
Batteries Not Charging dieseldrivr 6.0L Power Stroke Diesel 5 01-25-2010 11:41 PM
Tags
2006, altenater, alternator, alternetor, bad, battery, charge, diesel, f150, f250, ford, full, last, long, rating, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
