2004 6.0 Diesel F250 losing antifreeze - Ford Truck Enthusiasts Forums
Old 01-12-2011, 04:54 PM
Bmac65459 Bmac65459 is offline
Bmac65459 is starting off with a positive reputation.
Exclamation 2004 6.0 Diesel F250 losing antifreeze
I am new to this thread posting so bare with me, I have a 2004 F250 with the 6.0 Diesel. I am losing approxiemetly 1 gal of antifreeze per week. Only driving 2-3 times per week for 85 mile round trip. I cant find any evidence of external leakage. My oil level is staying the same. Can the block heater boil it out at that rate? I plug it in every night because its winter and I never know when I will need it. Any suggestions will be greatly appreciated.
Thanks BMAC
Old 01-12-2011, 04:59 PM
gearloose1 gearloose1 is offline
gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.
Stop driving. Nothing to do with block heater.
You must be seeing white smoke or smell it coming out of tail pipe.
Go to tech folder and see diagnostics procedure for seeing if you have a busted EGR cooler and details as to how to fix.
If you keep driving, you risk hydrolock (engine destruction).
Do products of combustion check in coolant to verify head gasket / bolts.
Mileage? Mods? Maintenance? Oasis report?
Old 01-12-2011, 05:13 PM
Sullid01's Avatar
Sullid01 Sullid01 is offline
Sullid01 has a good reputation on FTE.Sullid01 has a good reputation on FTE.
Listen to Gearloose - this is a serious situation. That's a lot of fluid. Look for white specs or coolant all over the engine near the degas bottle - you are likely loosing it through puking. New engines are not cheap and you definitely have a problem.
Old 01-13-2011, 08:06 AM
Thanks for the info, dropped off at the dealer this morning and am waiting to see the diagnostics. It has 101750 miles and I have owned since new. Change oil regularly use Rotella 15W 40 change fuel filter every 10,000 miles, put in a new air cleaner at 100,000 had some electrical updates for engine done around 75000 other than that just a good running farm truck pull hay trailer through summer. Where do I need to look on this site to get the updates or upgrades to this 6.0. Is there some things that I should do to it that I havent? Please advise. Thanks for your Input Bmac
Old 01-13-2011, 08:24 AM
Look up bismic's list of suggested updates.
If you have bad EGR cooler, oil cooler must be replaced.
Coolant filter a must.
If you have heads lifting, there is a fix...
Get latest flash..
Old 01-13-2011, 08:26 AM
Thanks appreciate the info Hopefully not to expensive, Need to keep her going.
Bmac
Old 01-13-2011, 04:26 PM
vloney vloney is offline
vloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant future
HMMMMM.........lower radiator hose.
Old 01-13-2011, 05:04 PM
There is a chafe point with the lower rad hose.. check there.. if the protector outer casing is not put on right..
Then there are the usual... bad clamps... etc.
Old 01-14-2011, 07:27 AM
Thanks
It was the lower radiator hose where it touches the steering gear box, thought I had this problem fixed from the last time it happened, just glad it was just that.
Old 01-14-2011, 01:16 PM
steelhead2's Avatar
steelhead2 steelhead2 is offline
steelhead2 has a good reputation on FTE.steelhead2 has a good reputation on FTE.
Quote:
damn,nice call vloney!.
Old 01-14-2011, 02:48 PM
Call number
Whats his number?
Disappearing antifreeze in 6.0L diesel fishwitch 6.0L Power Stroke Diesel 22 12-20-2016 12:22 PM
Need help 2004 F250 Bmac65459 1999 to 2016 Super Duty 3 02-10-2014 08:52 AM
Manual steering column needed bmac4020 1973 - 1979 F-100 & Larger F-Series Trucks 11 01-04-2014 06:47 PM
5.9 cummins F250 project bmac4020 1973 - 1979 F-100 & Larger F-Series Trucks 24 12-24-2013 10:28 PM
Key and Ignition Problems 2006 Ford F-250 bmac1 1999 to 2016 Super Duty 4 08-26-2009 12:52 PM
Tags
2004, 2006, 60, antifreeze, coolant, deisel, diesel, engine, excursion, f250, f350, ford, loosing, losing, truck, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
