04 Fuel in coolant, dealer says new heads??
Hey guys need some help! I ran from San Diego to San Francisco 2 weeks ago. I was pulling small trailer with maybe 3500lbs total trailer and cargo. I noticed what I thought was a coolant smell coming into cab. I pulled over let the truck cool down popped the degauss cap and saw what looked like diesel in the coolant. There was evidence of small spitting on the bottle. I took it to my dealer today. He called me and said that injectors were leaking at the brass insert in the head and that both heads had to be replaced. $6,600.00 plus.
Truck is an 04 with 83,000 miles and never really worked hard. No heavy loads at all. Does this sound correct? I have searched the forums and cannot find anyone else with this problem. Any help would be appreciated? Man I thought maybe dreaded h.g issue..This is too much!!
Mick, I hope you are right.. I will check on that asap. Talked to service guy @ Capo Ford.. He said probably contaminated coolant.
100,000 mile coolant,, truck was in for new coolant. I said hey man it was your oem coolant. Service manager said, oh could have been anything, ie..egr valve, oil cooler blah, blah, overheating I said check the diagnostics for overheating he said oh we cannot get a print out of that. I said bullsxxx. Man,, why argue with an idiot. What a frustrating ordeal. But thanks for the come back you guys! I need all the help I can get @ this point. I'm in San Clemente,CA.
You might want to take it to Bud at OCDieselShop in Mission Viejo for a second opinion.. He has a great reputation and is right up the road from you.. Go Tritons.. LOL
Fuel in coolant only comes from two places, a cracked head or a bad injector cup. Removing all injectors and pressurizing the coolant system, then using a soapy liquid determine whether the cup is bad or the head is cracked. Per Ford you are supposed to pull the head to replace the cup but it can be done in cab.
Unlike the 7.3L Power Stroke engine, a 6.0L injector lower fuel o-ring is above the fuel injector cup in the cylinder head. In order for fuel to leak due to a faulty injector cup BOTH the cup seal and the injector o-ring would have to fail at the same time which is extremely unlikely. Unfortunately the most likely cause is indeed a cracked cylinder head. I have seen three 6.0L PSD's come through my dealer's shop. While rare, this is a known issue.
If your truck were in my bay I would attempt to isolate which cylinder head is leaking by pressurizing the fuel line going to each head separately. A pressure tester teed into one of the degas lines can show a pressure increase. I also have read a suggestion that recommended removing the t-stat and watch for bubbles or liquid flow in the front cover with each fuel line pressurized separately.
Once a cylinder head is isolated as the leaker I would remove the injectors and inspect the seals, cups and injector bores for damage first...just to be sure. Then I would sell you a cylinder head after verifying that your diesel engine warranty has indeed expired.
Good Luck!
Keith, albeit not great knews I appreciate your response. Wow, I get the "rare" problem. If this is indeed a cracked cyclinder head. what are the causes and how to prevent in the future? The time of this post is 3:24am ..Its keeping me up this night..I like my truck and need it to work for me...
