1985 F150 Not getting Fuel to Fuel Pump - Ford Truck Enthusiasts Forums
Old 01-12-2011, 03:22 PM
Mr. Badger Mr. Badger is offline
Mr. Badger is starting off with a positive reputation.
I have a 1985 F150 that was running great. Now it will not start. I have done the following:
-New Fuel Filter
-New Mechanical Fuel Pump
It has a 2 barrel carb and two gas tanks.
I have NO fuel at the primary of the fuel pump. I tested with air pressure that should have forced fuel out of the fuel line and nothing.
Any advice is greatly appreciated.
Old 01-12-2011, 05:56 PM
bashby's Avatar
bashby bashby is offline
bashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to all
Are you SURE its not out of gas? Gauges lie sometimes.
Old 01-12-2011, 06:02 PM
Filled it up right before she quit.
Old 01-12-2011, 07:44 PM
bashby's Avatar
Are you saying you pressurized the tank with air and got no fuel? I would think you would but if not make sure its not blowing air out of the fuel line, its possible the pickup tube has a hole or is broken inside the tank. Can you feel suction on the fuel pump inlet while cranking? I've seen the fuel pump eccentric bolt come loose.
1985 f150 fuel pump relay question captain1997 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 03-08-2016 09:11 PM
1985 f150 fuel pump relay missing! captain1997 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 09-27-2014 06:24 PM
Fuel level sending unit for 1985 F150 carbureted????? frito-bandito 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 30 05-14-2014 08:56 AM
no ground supplied by ecm 1985 f150 brookslion1 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 27 07-04-2011 07:30 AM
Fuel sender for 1985 F150 6 cylinder superduteef250 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 05-17-2010 09:33 AM
Tags
1985, 1986, 85, 86, f150, f250, ford, fuel, gas, geting, placement, pump, starting, system, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
