Replaceing the Check engine light bulb - Ford Truck Enthusiasts Forums
Old 01-12-2011, 10:28 AM
mwood1973 mwood1973 is offline
mwood1973 is starting off with a positive reputation.
Turns out the Check Engine Light bulb is burnt out. I have to replace it to get an inspection sticker in Texas. I have a 1997 Explorer with a 5.0. I have read online and the manual I have to pull the dash board to replace the lights. Does anyone have any tips or suggestions on making this easier? Thanks in advance.
Old 01-12-2011, 11:59 AM
KhanTyranitar's Avatar
KhanTyranitar KhanTyranitar is offline
KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.
Yes, replace all the bulbs at the same time, that way you don't have to do it again. I personally would replace them with LEDs.
Old 01-12-2011, 06:48 PM
shorod's Avatar
shorod shorod is offline
shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.
If you go the LED route, make sure you got the polarity correct before buttoning up the instrument cluster. I don't think there are many LED retrofit options that are not polarity sensitive, but I could be wrong on that.
-Rod
Old 01-12-2011, 07:03 PM
MCDavis's Avatar
MCDavis MCDavis is offline
MCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputation
I've done it. It's not difficult, just a lot to remove. As previously stated, replace all the bulbs at once since you'll be back there anyway.
Old 01-12-2011, 07:07 PM
MCDavis's Avatar
I knew I had a post about this somewhere. Just located the old thread.
http://www.ford-trucks.com/forums/10...s-are-out.html
question about function of bulbs up front choate 1987 - 1996 F150 & Larger F-Series Trucks 6 01-16-2015 06:00 PM
2012 F250 Headlight Bulb Replacement skscci 1999 to 2016 Super Duty 9 04-07-2012 05:55 PM
Check engine light bulb ttimmy58 Explorer, Sport Trac, Mountaineer & Aviator 5 03-27-2012 10:21 AM
Fog Light Bulb Replacement kjsway 2007 - 2014 Expedition & Navigator 3 12-02-2008 04:57 PM
Dash light replacement sorensenj Ranger & B-Series 5 11-10-2008 09:12 AM
Tags
91, 96, 97, 98, bulb, check, dash, e150, engine, explorer, f150, ford, light, lightbulb, replace
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
