How to install ARP head studs?
#62
well I'm curious if you're confusing what a lot of the oil burners, and some people here used to say..
Having to torque and loosen like 4 or 5 times to break the thread in. If you use ARP lube there is absolutely no need for that, it will hit target clamp load on the first set.
#63
6.9l: http://arpinstructions.com/Instructions/150-4069.pdf (note #4)
7.3l: http://arpinstructions.com/Instructions/250-4204.pdf (note#5)
The recommended torque values are when using the ARP ULTRA-TORQUE FASTENER ASSEMBLY LUBRICANT. They claim it comes in the kits but mine did not. I had none available and for this reason is why I torqued mine to the higher value, per ARP's recommendation.
#65
#66
I got my heads off today, gonna try to put them back on tomorrow and start torquing the studs...on the passenger side head, 3 bolts couldnt come all the way out due to clearance issues, this will probably be an issue putting the head back on with the studs in the block. I was wondering if I could set the head on the block and then thread the studs into the block, I mostly see people put the studs in the block first, then set the head. Does it matter?
#67
#69
darkestskydiver
Modular V8 (4.6L, 5.4L)
11-05-2011 01:20 AM
