Has anyone siphoned gas out of the gas tank behind the cab of a 79? I just tried doing it with no success. I've siphoned the tank in rear but not behind the cab.
sorry i should have mention that i drop the tanks an remove the fuel pump /sending units. an shove the hose down though that hole because a lot of tanks have some kind of anti siphoning devise in them
I have put pin switches on the gas flap of customer's rigs when I do alarms to stop a problem with siphoning.
the 'device' to prevent siphoning is basically just a metal screen, which you can stab through with a sharp object. piece of conduit with the end cut at about a 30 degree angle.
