92 bronco gear shift broken?
This could possibly be a simpler fix than anticipated. The shift linkage in your 92 has a pair of small screws at the base of the steering column. They are notorious for working loose and creating a misalignment of the shift indicator and not always going into the gear selected. Eventually they will work all the way out. Check the driver's side floor carefully. Replace them or tighten them and all should be back to normal.
Now I'm the one having issues with my shift linkage, my shifter tube was broke and I replaced it, I think I haven't calibrated shifter properly, but it has been way too hard moviing it down at the transmision, like something is stuck inside. Where can I find the shift linkage bushings I've seen mentioned in several threads?.
Here is the rest of the info btw: https://www.ford-trucks.com/forums/1...oken-help.html
curbthrasher
27
02-21-2017 08:04 AM
richierand95
1999 to 2016 Super Duty
08-16-2016 07:51 PM
sixkiller
08-06-2015 10:16 AM
fisher4life
09-30-2014 08:28 AM
anelson2964
06-19-2014 02:17 PM
