edelbrocks new 94
Do you have it together with gaskets when you do this? I usually just hold the discharge nozzle down with my finger. Reason for asking is that you may find the gaskets "off" a bit in thickness. You can tighten the clamps down, the bars are tight, but the discharge nozzle is loose-too thin a gasket.
i did this with carb apart. something got in there and plugged her up. i got it clean and can put air thru both sides, but it seems a little weak on right side. i think there may be a remnant stuck on "wall" of squirter that is impeding the flow. tore left rotater cuff last week at work, so won't be able to do much for a couple weeks, but saw this and am not afraid to ask those who know. i appreciate and respect others knowledge and expertise, will listen and act on this knowledge, and if i can't get it right, will definitely ask for help.
70-360fe
21
04-18-2013 05:35 AM
