e4od shift points HELP - Ford Truck Enthusiasts Forums
Old 01-11-2011, 01:17 AM
screaminford screaminford is offline
screaminford is starting off with a positive reputation.
in a 1990 e4od with a transfer case mounted VSS, can i change the shift points by changing to a different speedo gear?
basically im trying to trick the trans to shift at like 5500 rpm in drive or more without a aftermarket controller. if i use a way lower speedo gear, so for example i am going 55 and the computer thinks im going 40, will it shift that gear at 55 when it would normally shift at 40 because it acually thinks it is doing 40? or does it also base shift points off of the tach? but i have read nowhere the e4od uses any info from the tach except on the 7.3 idi diesels.
but, if it does run on the tach, can i trick it by putting some kind of resistor on the tach wire going to the trans so it thinks its running like say 1000 rpm less then its actual rpm?
and on a 1990 5.8 efi, what is all the sensors the e4od uses to operate correctly?
all i can think of is the VSS, TPS, AND MLPS. and does anyone know if the ecm uses the tach to control the trans?
if anyone can even understand my ramblings, any help with this would be greatly appreciated.
i am going to try tomarrow and swap out my current speedo gear (speedo matched for 4.56 gears and 35 inch tires) to my stock speedo gear and compare the rpms at which it shifts at full throttle to see if the speedo gear idea will work. i have a feeling it wont.
thanks guys
Old 01-23-2011, 05:20 PM
F350 BAMF's Avatar
F350 BAMF F350 BAMF is offline
F350 BAMF is starting off with a positive reputation.
BUMP...
I too am curious if the transmission gets any readings off of a tach signal? My E4od shifts weird and the tach is REALLY off!!!
Old 01-23-2011, 07:57 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is online now
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
The E4OD looks at the tach for some of the shifting, usually WOT shifts. The tach signal is a frequency, not a voltage. Using a resistor might just make the PCM not see the signal at all. That will really mess with it.
Old 01-23-2011, 09:43 PM
F350 BAMF's Avatar
Quote:
Originally Posted by Conanski View Post
Pin 5 of the TFI module on the distributor goes to pin 4 on the EEC through a 22k ohm resistor, check that resistor and the wire for continuity and if good replace the TFI module, be sure to get another grey one and not a black one.. it is wired differently.
Mark thanks, I found this... Your speaking of this resistor?
Old 01-24-2011, 05:55 AM
No, I'm not. I'm talking about screaminford's question about adding a resistor to the tach circuit.
Old 01-24-2011, 10:29 AM
Well on that diagram the wire that feeds the tach signal to the eec does have a resistor on it. What about adding a bigger one?
E4OD intermittent limp mode, working tach and speedo 96inline 1987 - 1996 F150 & Larger F-Series Trucks 4 11-08-2015 09:59 PM
1990 7.3 tach problems AndysFords Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 08-03-2015 05:34 PM
E4OD early shifting-TPS adjustment? jjqllc Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 1 07-29-2014 10:42 PM
cruise control help Jayme Duty Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 01-29-2011 08:57 PM
VSS and PSOM question... fkaster01 1987 - 1996 F150 & Larger F-Series Trucks 6 04-02-2009 07:27 PM
Tags
1990, 58, 73, 95, bronco, change, controller, e40d, e4od, f250, ford, point, points, shift, stock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
