U Bolt Torque Spec & Zerk Fittings Location - Ford Truck Enthusiasts Forums
Transit Connect 2010+ Ford Transit Connect
Old 01-10-2011, 06:45 PM
Cy Madrone Cy Madrone is offline
Cy Madrone is starting off with a positive reputation.
Ford recommends re-tightening UBolts at 15K intervals.
Does anyone know torque specs?
Also the manual states that Zerk fittings need to be lubed.
Are there any on the TC and if so, where?
Old 01-29-2011, 11:33 PM
ncranchero's Avatar
ncranchero ncranchero is offline
ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.
NOTE: Tighten the U-bolt nuts evenly in a cross-type pattern with the weight of the vehicle on it's wheels (not jacked up it means)
Tighten the U-bolts nuts to 125 Nm (92 lb-ft).
Old 08-11-2011, 03:33 PM
More info on U-Bolt tightening & Zerks... NOT!
Firstly thanks ncranchero for torque info.
I additionally learned that one needs an uncommon socket size, an 18mm DEEP socket to tighten. One of the 4 bolts on each side additionally requires a 3" extension to clear a suspension part.
As for lubing the Zerk fittings...there are none! Just "boilerplate" info printed in the maintenance schedule that does not apply.
How its made: FTE zerk fitting Snowseeker Excursion - King of SUVs 27 02-28-2015 10:59 PM
slowly working way through vibration - question JimPat Excursion - King of SUVs 23 04-26-2010 01:55 AM
Fitting zerk fittings to non-zerk ball joints. EXv10 1999 to 2016 Super Duty 21 06-18-2009 12:15 PM
How Many Zerk Fittings SC_Dave 1999 - 2003 7.3L Power Stroke Diesel 13 01-05-2009 09:23 PM
2006 6.0 L Diesel 4X4 -Zerk fittings to lube Gary A. 6.0L Power Stroke Diesel 8 03-01-2008 09:50 AM
Tags
bolt, correct, cy, drive, fitting, fittings, ford, lincoln, madrone, mkx, shaft, specs, sportrac, torque, zerk
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
