Go Back   Ford Truck Enthusiasts Forums > Misc. > Air Intakes, Air Filters & Ram Air
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 01-10-2011, 05:08 PM
Old_Ford_Man's Avatar
Old_Ford_Man Old_Ford_Man is offline
Garage is empty, add now
Old_Ford_Man is starting off with a positive reputation.
Ford FE Intake Manifold ID & Applications
Part NumberEngineYearTypeMaterial
Bore Diameters
Port Sizes
Remarks
PrimarySecondaryWidthHeight
C1AE-9424-A3521960-612V DualIron1.601.162.14
C3AZ-9424-F3521962-632V DualIron1.601.162.141/4 inch Temp sending unit
C4AZ-9424-A352/3901963-642V DualIron1.601.162.141/8 inch Temp sending unit
C4AZ-9424-B382/3901963-644V DualIron1.601.601.162.141/8 inch Temp sending unit
C6AZ-9424-D3901965-672V DualIron1.601.162.75
C9AZ-9424-E3901968-702V EqualIron1.601.161.82
C1AE-9424-B352/3901960-614V DualIron1.601.601.162.14
C3AZ-9424-E3901962-634V DualIron1.601.601.162.14
C9ZZ-9424-A352/3901965-694V EqualIron1.701.601.161.82
C3AZ-9424-C352/390/4061960-634V DualAluminum1.621.721.162.14
C3AZ-9424-D390/4061961-636V SingleAluminum1.56 all1.162.14
C3SZ-9424-A390 SPL1962-636V DualAluminum1.56 all1.162.14
C8AZ-9424-C390/410/428 Std1967-684V DualIron1.601.601.161.75
C3AZ-9424-J427 LR1963-644V DualAluminum1.721.721.142.20
C4AE-9424-G427 HRALL4V DualAluminum1.721.721.242.60for the 780 cfm Holley carb, dual plan
C6AZ-9424-M427 MR19684V EqualAluminum(2) 1.78 x 2.50 Oval1.241.94Before 11/1/1966
Best all round intake, single four barrel, sidewinder design
C8AX-9424-B427 TPALL4V SingleAluminumRounded Tunnel Ports, single plane, single four barrel
C5AZ-9424-C427 LR1963-658V DualAluminum1.62 all1.142.20
C8AX-9424-A427 MRALL8V SingleAluminum1.72 all1.241.94Single plane, dual four, tunnel type,
C5AZ-9424-G427 MR19678V EqualAluminum1.72 all1.241.94Dual plane, dual four barrel
C4AE-9424-F427 HRALL8V DualAluminum1.62 all1.242.60dual plane, dual four barrel
C7OE-9424-A427 TPALL8V SingleAluminum(2) 3.75 x3.75 Square2.202.05Rounded Tunnel Ports, single plane, dual four barrel
C7OE-9424-B427 TPALL8V DualAluminum1.72 all2.202.05Rounded Tunnel Ports, dual plane, dual four barrel, strip or street
C6AZ-9424-H428 PI1966-694V DualAluminum(2) 1.78 x 2.50 Oval1.241.94Second best intake, single four barrel, Police Interceptor 428 model, the cast iron model is the same just 55 lbs. heavier
C8OZ-9424-B428 PI
428 CJ/SCJ
1966-70
1968-69
4V DualIron1.601.701.241.94
Legend:
LR = Low riser
MR = Medium riser
HR = High riser
TP = Tunnel Port
PI = Police Interceptor
CJ = Cobra Jet
SCJ = Super Cobra Jet
Tags
240, 272, 390, aluminum, barrel, bbl, c3az9424d, dual, fe, ford, id, intake, manifold, manifolds, partnumbers, single
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
