4 WHEEL DRIVE NOT WORKING - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 01-10-2011, 05:50 PM
DJMORETON DJMORETON is offline
DJMORETON is starting off with a positive reputation.
I have a 07 F350 diesel, 4wd not working:
#1 have 12 inches of vacuum at the output of the pump AND the solenoid going to the front hubs, is this enough vacuum to fully engage the hubs?
#2 I found that the inside seal on the drivers side is not completely seated,( pump does not shut off) and I can't create any vacuum (manually) directly from the hub like I can the other side.
I plugged that line ( bad side - pump shuts off) , engaged 4wd thinking I would get power to the other side ( good side) , but I did not ,,,,,,I'm thinking either 12 inches of vacuum is not enough or possibly it is, and being that the front axle is not ''POSI TRACTION'' (probably not) the differential can't/won't push power to the good side ???. Any help is greatly appreciated, especially if you know for sure the designated vacuum amount from ''out of the box condition'' ?
Also the heater has been defaulting to the defroster, if I shift the 4wd into 4 WD or out of 4WD the heater will go where it is suppose to.,,,,i.e. vent or floor mode,,,,,Thanks for any help, DON
Old 01-10-2011, 06:10 PM
1975StroppeBaja's Avatar
1975StroppeBaja 1975StroppeBaja is offline
1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold
I don't recall the exact numbers, but 12in sounds reasonable. Also, it sounds like you found where your leak is and that would cause the defroster problem you mentioned.
No, your front diff is not "posi trac"/limited slip/locked/etc unless someone put an aftermarket unit in.
Have you tried just turning the hubs to LOCK manually? That should get your 4x4 working until you get a chance to fix your vacuum leak.
Old 01-10-2011, 06:17 PM
4 WD not working
Locking the hubs manually does work but i figured if i plugged the bad line i would get 4wd on the fly to the good axle without locking the hubs in,,,,,but that is not working.
Old 01-10-2011, 07:00 PM
Maxium4x4's Avatar
Maxium4x4 Maxium4x4 is offline
Maxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputation
I'm not an ESOF person, I have manual. From what I understand the vacuum will pulse for 45 seconds to lock the hubs and 15 seconds to disengage the hubs. 10 or higher is sufficient to lock and unlock the hubs.
Old 01-10-2011, 07:02 PM
Maxium4x4's Avatar
Quote:
Lock both hubs manually if you have to, one on and one off is not a good idea.
Old 01-10-2011, 07:51 PM
Yeah, that won't work. Even if you did have a locker up front, like Maxium4x4 said, it would be a bad idea to run like that.
Old 01-10-2011, 08:31 PM
I plowed with the hubs manually locked and did fine, don't know if both hubs had power or not but figured plugging the line would cure the problem, at least to get the shift on the fly working, at least to one wheel. However I'm not sure the vacuum control solenoid is doing it's job. With everything hooked up the heater defaults to the defrosters, if I activate the 4wd, the heater will act as it should. I'm wondering if there is another componet that is preventing the correct electrical charge from being sent to the solenoid. There is one plug with 3 terminals....
Sorry for the late response, had to run out, back now. pulling my hair out,,,,
Old 01-11-2011, 09:36 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Sounds like your solenoid is leaking vacuum if the pump runs constantly. In your other thread asking about aftermarket vacuum solenoids, I doubt it.
Everything You Wanted To Know About The IWE System...And Then Some xjcamaro89 2004 - 2008 F150 404 01-03-2017 01:59 PM
FRONT HUBS WON'T LOCK Rongold 1999 to 2016 Super Duty 13 11-24-2015 09:24 PM
4WD vacuum line '98 Ranger PUZZLED gpdickert Ranger & B-Series 1 07-04-2013 10:01 PM
Vacuum Pump (4WD and AC) mmenzies 6.0L Power Stroke Diesel 22 11-07-2012 01:02 AM
IWE PROBLEMS! Need Help wats504 2004 - 2008 F150 7 01-20-2011 06:40 AM
Tags
2003, 2004, 4wd, 99, drive, engageing, engaging, f250, f350, ford, hubs, problem, wheel, wheels, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
