86 4.9l oil pressure?
well found out today my 86 bronco i bought has a blown head gasket. added almost a gallon of coolant into the radiator and started it up and it was smoking bad.
but recently i seen that the oil pressure on the aftermarket guage was reading about 20psi. what should it be at? it mostly read 40psi when i would drive it. what should i check for when i replace the head gasket?
cracked head
well got the head off, took a look at the gasket it was fine, then i took a look inside the cylinder wall it was fine, then the head and it had about a 1.5in crack up to the valve. i havent really check the coolant when i bought the truck in november. well i got a spare head im going to pop of another engine and check out. probably just get everything checked out and make sure it is good before i throw it on. what is the engine supose to be at for sure on oil pressure?
i will be pulling the oil pan off to replace the gasket and i mise well do the pump if its bad.
im not to upset cause i bout the bronco for $450, it just needed a carb and havent had a problem since. and i have a spare 4.9l that i got for $40.
now the only thing im upset about is that the guy installed a after market water temp guage in place of the wire and so it is just a metal wire that heats up, everytime i have looked at the temp guage it was fine, but is is cold out so the cold air would have cooled it down
No, cold air wouldn't cool it down, that line is full of either or butane, something like that. As the end of it heats up, it pressurizes more and moves the needle. As for the oil pressure, I have no idea what it should be. I just know that is in a decent safe range for it. If you are really worried, get some plastigauge and check clearances.
86stepsideF150
06-28-2010 09:23 PM
