Go Back   Ford Truck Enthusiasts Forums > Ford Vans and other vehicles > Ranchero & 1961 - 1967 Econoline
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 01-10-2011, 02:06 PM
mach1god mach1god is offline
1974 Ford Ranchero
mach1god is starting off with a positive reputation.
'73-'74 Ranchero decode needed
I am about to start work on this car and I would like some help with the decoding. The "VIN" states a 1973 but the front clip is a 1974, any help is vary much appreciated.
VIN: 3A3OH300934
EMISSIONS: D6AE-9C485-VE
DOOR PILLER: 4A48S115839
DATE: 09/73
BODY: 97R
COLOR: 2B
TRIM: CA
TRANS: U
AXLE: 6
DSO: 71
  #2 (permalink)
Old 01-27-2011, 07:48 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by mach1god View Post
I am about to start work on this car and I would like some help with the decoding. The "VIN" states a 1973 Gran Torino but the front clip is a 1974.
This 1973 VIN is in-correct for a Ranchero: 3A30H300934 30 = 1973 body style 65D Gran Torino 2 Door H/T Formal Roof.
The following info is correct for a 1974 Ranchero GT.
DOOR PILLER: 4A48S115839 // DATE: 09/73 / BODY: 97R / COLOR: 2B / TRIM: CA / TRANS: U / AXLE: 6 / DSO: 71
If the 1973 VIN is located on the left corner of the dash, visible thru the w/shield...something smells and it ain't hay. If located on the door, the door was changed at some point, prolly due to damage.
The VIN on the dash is supposed to match the VIN on the Warranty Plate. If the dash VIN does not match, you may have a stolen vehicle. When vehicles were stolen, the dash VIN was altered.
Look for the hidden VIN, it was stamped either on the radiator support, or the left fender apron. There is another hidden VIN stamped on the frame rail.
4 = 1974.
A = Atlanta GA Assembly Plant.
48 = Ranchero GT, body style 97R.
S = 400 2V
115839 = 1974 Numerical Sequence of Assembly.
9/73 = 1974, assembled September 1973.
97R = Ranchero GT.
2B = Bright Red.
CA = Black all Vinyl.
U = C6 Cruise-O-Matic.
6 = Ford 9" Rear Axle / 3.00-1 / non Limited Slip.
71 = Los Angeles (SoCal) Ford District Sales Office, where the original selling dealer ordered the Ranchero from.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #3 (permalink)
Old 02-02-2011, 09:32 PM
1974 Ford Ranchero
thanks for the info. will check hidden vin.
  #4 (permalink)
Old 01-28-2013, 04:35 PM
jas88's Avatar
jas88 jas88 is offline
Garage is empty, add now
jas88 has a good reputation on FTE.jas88 has a good reputation on FTE.jas88 has a good reputation on FTE.
Is it possible that Ford made a running change on the later 73 Rancheros to the upcoming 74-style grille? I am seeing a lot of Rancheros that are advertised as 73 models with the 74-style grille and header. I know you can put a 74 grille/header on the 73 fenders, but I just think I am seeing too many of them this way that it is just happenstance that so many POs switched them over. Did Ford perhaps run out of 73 grilles or headers late in the run and just decided to switch over early instead of making more obsolete parts?
__________________
1974 F350 Wrecker 360/T18
1991 F150 SuperCab 4x4 7.5L/ZF5
1991 Bronco SAE 7.3L IDI/ZF5
2005 Escape 2.3L/CD4E
  #5 (permalink)
Old 02-02-2013, 01:38 PM
Ford Parts Guru
2013 Ford Escape
Quote:
No, absolutely not, this would have affected all Torino's, not just Ranchero's. It never occurred.
Both the grilles and header panels were still available in 1983!
Advertised as 1973 models but are actually 1974's. 1974 production began in August 1973 as new vehicle introduction time began in September.
Back then, some states registered vehicles in the year they were first sold .. not by their actual model year.
Look at the upper corner of the Safety Standard Certification Label for the production date. The VIN begins with the year.
__________________
  #6 (permalink)
Old 02-09-2013, 08:45 PM
jas88's Avatar
Thanks Bill! That thing about registering them to the year they were sold makes sense to explain what I am seeing.
__________________
Tags
1973, 1974, 1978, 74, code, decode, decoder, decodin, dso, f150, ford, pre, ranchero, red, torino, trim, vin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
