DPFE Sensor location on Ford F250 2006 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 01-10-2011, 02:24 PM
Mike-11 Mike-11 is offline
Mike-11 is starting off with a positive reputation.
Hello Everyone,
Just wanted to know if anyone know where the DPFE Sensor (Delta Pressure Feedback Electronic Sensor) is located on a Ford F250 XLT 5.4L.
I look on the fire wall and driver side of the engine and I can't find anything. I believe I'm looking for a unit that has two hose coming out of it. Diagram or picture will be helpful.
Thanks,
Old 01-10-2011, 02:31 PM
redford's Avatar
redford redford is offline
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
IIRC, a 3v 5.4L engine doesn't have a DPFE sensor.
Old 01-10-2011, 02:49 PM
redford - Are you sure about that? I was searching around and the unit is flat with two tubes coming out of it. Some site tell me is located on the fire wall, enigine (driver side) or on the exhaust manafold. I believe I have to remove my Air filter unit and it will be under that. Again I'm not so sure.
I will call a ford dealer and see what they say. If I get any infomation I will post it.
Old 01-10-2011, 02:57 PM
sorry I meant intake manifold not exhaust.
Old 01-10-2011, 03:21 PM
redford- You are right, the 3V engines do not have a DPFE sensor. The Ford dealer could not bring up a part for that year and model.
I posted a P0174 code (System too lean - Bank 2). When I looked up the code it stated check MAF (Mass Air Flow) sensor. I clean the MAF but the truck still rides rough. It loses power once an while when driving. When you come to a complete stop the truck shakes like crazy.
I don't know if I need a new MAF, do you have any ideas.
Ford F250 XLT 5.4L 3V (8 cyl)
Old 01-11-2011, 09:34 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Check for vacuum leaks.
Old 01-11-2011, 09:50 AM
redford's Avatar
Also (may sound silly) but check your PCV valve also.
Old 01-12-2011, 12:26 AM
DernMooseAk DernMooseAk is offline
DernMooseAk is starting off with a positive reputation.
He really cant check the PCV, its under the valve cover. Really! Actualy I was told by ford it is part of the valve cover. Want to replace PCV, you have to replace Valve cover....
Old 01-12-2011, 06:40 AM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
what about an O2 sensor? I know there is a specific code for that but could it be a factor here?
Will a bad DPFE Sensor Make a Truck Run Rich? GuitarJesus 1987 - 1996 F150 & Larger F-Series Trucks 10 06-11-2016 07:26 PM
01 e250 p0171 & p0174 dafish13 1997 - 2003 F150 2 06-12-2012 10:55 PM
Engine code P0174 Mike-11 1999 to 2016 Super Duty 3 01-10-2011 12:04 PM
P0401 / P0402 deejdeej Ranger & B-Series 4 06-10-2010 10:51 PM
DPFE Sensor Part # for '98 Expy 5.4L?? Phil056 Expedition & Navigator 3 10-26-2004 05:16 PM
Tags
1999, 2001, 2006, 250, 46l, dpfe, duty, e150, f250, find, ford, installation, location, maf, sensor, super, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
