Dash bezel questions
Just wondering if anyone has come across an '81 Ranger/XLT/Lariat gauge bezel from a non-AC truck? I found a tach gauge cluster on ebay and got what I consider to be an excellent deal on it, would like to find a woodgrained gauge bezel to surround it, also a woodgrained radio/heater control bezel. Another question I have is how many shop manuals there are for the '81 F150, and their titles? Thank you for your help in finding the answers to these questions!
On the other hand, the woodgrain/pretend chrome trim guage cluster was available without the A/C vents in it. I have one here that came out of my 80. Only one issue, dealer added A/C, so they cut holes in it for the A/C vents....
The radio/HVAC bezel is no different between A/C and non A/C. There are differences for various radio options though.
Yeah, they exist, but are kinda rare. I think the ranger trim (80-81) or XL (82-86) were the lowest trim levels to get a woodgrain dash. 85-86 typically had a different woodgrain pattern.
It's a bit rare to see the mid-level trim without A/C in the southern 1/2 of the country.
When looking, keep in mind that 1980 has a different layout for the upper row of warning lights. The seatbelt/brake lights swapped places with the turn indicators for 81-86, and the high beam indicator was dramatically dimmed as well. The 80 HB indicator will blind you at night.......
I put an 85 cluster in my truck, along with an 81 gauge bezel. I intended to grab the 85 bezel, since I have a matching radio bezel with the newer woodgrain and single rectangle opening for installing later style radios, but I had brain fade and forgot it......
Using an 81+ cluster in an 80 requires extensive rewiring. Took at least 30 seconds to complete........ (Thanks ri truck guy!)
But I wonder why Ford swapped the seat belt and brake lights with the turn signal indicators? From the driver's seat in my '85, my steering wheel rim is right in front of both turn signal lights. I have caught myself driving along with my turn signal still blinking a few times because I couldn't see that the turn signal light was still on. The steering wheel blocked it from immediate view.
The light arrangement made better sense on the 1980 models, in my opinion.
I never knew that the "HIGH BEAM" light indicator was brighter on the 1980 models.
As for the turn indicators & seatbelt/brake warning lights moving, no clue. But, you're right, the wheel rim can block seeing the turn idicators on the newer ones. I don't think there was anyway a person could miss seeing the brake warning light, as bright as it is, but that *might* be the excuse....
But yes, everybody here has been correct. I have a non A/C bezel in my truck from a 1982 XL trim truck. I have seen a few non A/C high trim trucks, but as it's been said, it's pretty rare. The ones you'll continuously find will be the black base trim bezels.
Rogue, don't remind me about the bezel differences. I still have to figure out whether or not the lights in the F100 are correct because of the 82 cluster. lol.
I am not sure about 1981 but in 1983 there were four shop manuals:
Engine
Engine/Emissions Diagnosis
Pre-Delivery Lubrication Maintenance
Body, Chassis, Electrical
My Dad had and '83 F250 and always ordered the factory manuals. He sent them to me when i bought my '85 F150. Not everything is the same but they do help out quite a bit.
Erik
1985 F150
300-6
4spd OD trans
Engine
Erik
1985 F150
300-6
4spd OD trans
What he said. Just be sure to check the color of the printed circuit board on the back. 1980 = green, 81-86 = red. As mentioned before, they are a bit different, but with the right bezel and wire repinning, they can be interchanged.
If your truck has oil/alt lights, the gauge cluster is not compatible.
Wunnerful, wunnerful! My truck has the gauge package, so I will wait a little more excitedly for the tach cluster to arrive (ETA Friday after work!). Thank you for the info. Reading the posts in this thread makes me wish I had the '80 bright light indicator- from my vantage point, the one in my '81 is nonexistant unless I scrunch down in the seat...
